TH-42PD60U: PA or H Board
  • bluefuse
    • Nov 2011
    I have a Panasonic TH-42PD60U that blew both F401 hot fuse and F402 neutral fuse. I replaced both fuses and I am now in standby mode with an LED blinking code 10. Service manual gives this code a PA-SOS/Tuner SOS error that relate to test points at the PA-Board and/or H-Board.
    My question is what are the tests that I need to perform to determine which of these two boards I need to replace. Thanks in advance.
  • randtek
    • Oct 2011
    • 280
    • US
    Re: TH-42PD60U: PA or H Board
    The troubleshooting for that has quite a few steps. 10 blinks can be caused by any of about 9 boards in these. I found this with a google search.
    Panasonic TH-nnPX60U Troubleshooting
    • bluefuse
      • Nov 2011
      Thanks Randtek,
      Before I noticed the LED blinking I used the No Power flow chart that led me to replace the DG board but that wasn't it. This doc is better...I will use the blinking 10x BEFORE pressing the power button diag on page 25 tonight and see where it leads.
      • Tvbob
        tvbob
        • 204
        Hello, I am trying to use Randtek troubleshooting link to diagnose a 10 blink at plug in on a Th50PX80u plasma. what is the (pa board) ?
        • bluefuse
          • Nov 2011
          On the 60u it is the smaller board to the left of the P board with a ribbon cable going down behind the tuner board. Look at the connector names...they will start with PAxxxx. Also there are two different 10x blink codes. One that starts as soon as you plug in AC power and one that starts after you push the power button. good luck.
          I found a bad P board and will replace the bad transistor and resistor...whole board is almost $100.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • Hakuu
            by Hakuu
            Hi There,
            More Details
            TV Model - LG OLED77G1PUA
            07-12-2023, 02:37 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
