Panasonic TC-P50G15
Re: Panasonic TC-P50G15
The diode VXST3D82BL3 is out from the board and no reading when tested .
I try to made up with two diodes for the same value,could you help me tw2005
to buy the right ones from this site http://www.rapidonline.com/
thxComment
thxComment
This diode reads "Nothing" because of it's configuration. It's a dual chip that operates in the Reverse direction only. You won't measure a blocking forward voltage on this device. You will not get this to beep using your meter. Make sure that if you took this out of the board to test it that you put it back in the correct polarity, it's a zener in one direction and a rectifier in the other. Put it in backwards and you will certainly blow up this device!Comment
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by riparoHi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
I attach a link to download the service manual, thank you for anyone who can help me
https://tel-spb.ru/download/?brand=P...0E_LA73.rarβ - Loading...
