Philips 42PF7320 plasma, strange problems
    Re: Philips 42PF7320 plasma, strange problems
    And, your meter may be set to VAC?
    On some panels Vset is measured as Vs+Vset so subtract Vs from it to get actual Vset.
    • DPark
      • May 2013
      • 26
      Thanks for the info. I haven't been able to get back to the TV project for a little while, but I will try the suggestions and I'll keep you updated.
      • DPark
        • May 2013
        • 26
        Ok, I briefly had a chance to get back to it tonight. I changed out the battery to the multimeter. Still have about the same results.
        • retiredcaps
          • Apr 2010
          • 9271
          Try putting your black probe on the connector pin marked GND (just below Vset).
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            To make sure your multimeter is working properly, try the following test.
            1) Measure the 5V standby rail with it set on 20V DC. It should read something like 5.00V.
            2) Measure the 5V standby rail with it set on 200V DC. It should read something like 5.0V.
            3) Measure the 5V standby rail with it set on 200V DC. It should read something like 5V.
            4) Report your findings for all above.
            If your multimeter is not working correct, which is possible, borrow/buy another one. In addition, if you want help fixing the one you have, start a new post and I'll make suggestions on what could be wrong.
            PS. One retiredcaps' bonus point for a picture of your multimeter.
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Whoops, just noticed my error in cut & paste above.
              The "correct" #3 is
              3) Measure the 5V standby rail with it set on 600V DC. It should read something like 5.0V.
              • DPark
                • May 2013
                • 26
                I tried the black probe (with red on the vset pin) to the pin connector ground as well as on the board at different points and it seems to range between 480-530V. Even the two ground pins in the same connector seemed to measure different amounts!
                I tested the multimeter at the 5v location retiredbadcaps sugggested. All seems normal.
                Multimeter at 600 - 4-5 (fluctuates) on the display
                Multimeter at 200 - 5.1 on the display
                Multimeter at 20 - 5.13 on the display
                • retiredcaps
                  • Apr 2010
                  • 9271
                  #28
                  My interpretation of your readings above is that your multimeter is defective when using the 600V range.
                  At 600, it should show steady/solid 5 because your standby voltage is a steady/solid 5.13.
                  When it is fluctuating between 4-5, the "4" reading suggests it can be between 3.51 and 4.49.
                  I suggest borrowing or using another multimeter to redo the vset reading.
                  Here is a link to your multimeter
                  As you can see on page 8, when it is set to 600V DC range, there is only one digit of resolution so it should show a steady/solid 5V.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    @DPark, what is your Vs+ reading?
                    If your multimeter is working correctly, then we need to know the Vs+ reading.
                    • DPark
                      • May 2013
                      • 26
                      Finally had some time to mess with this TV again. Model: 42PF222A/37 Power Supply: 44-00101B.
                      It will power on for about 5-10 minutes, but then shuts off after a couple of relay clicks. 5-blink error code when this happens.
                      All voltages seem to check out fine with the new meter I have when the power is on. The only one that seems to be more than 10% off is SND_P.
                      Factory Specs / Actual Reading
                      Va=70 / 70
                      Vsc=206 / 206
                      Se=86 / 86
                      Vset=195 / 194.2
                      5v2=5.2 / 5.17
                      5vsw=5.2 /5.15
                      8v6=8.6 / 8.64
                      12v=12.5 / 12
                      SND_P=18v / 20.2
                      Anyone have any suggestions on what else I should check or replace? I could just buy a refurb board for less than $50 but what fun would that be?
                        The voltages look fine -- I don't think the problem is with the PSU.
                        • celiabrown
                          Issue with Plasma Philips 37inch chassis FTL2.1
                          by celiabrown
                          Hello guys,
                          My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
                          Can someone has any symptom like this ?
                          Thanks​
                          05-09-2024, 10:56 PM
                        • Sharpa
                          Repair attempt Philips 55OLED804/12
                          by Sharpa
                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                          The symptoms when bought: Philips logo appears then tv turns off
                          Things tried so far:
                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                          11-22-2025, 08:30 AM
                        • alro7779
                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                          by alro7779
                          Hello, guys!
                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                          09-14-2025, 12:25 AM
                        • G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                          by G33RT
                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                          It does power up when pressing the power button.
                          I already try the power button while plugin the plug with no result.
                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                          Could this be an PSU or eMMC issue ?
                          07-19-2025, 03:43 AM
                        • jean luc ferre
                          laptop hp g72 b52sf screen problems
                          by jean luc ferre
                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                          06-07-2025, 03:27 PM
