50" Philips 50PFP5332D/37
  • BigKyle
    • Dec 2011
    Hey guys i have a 50" Philips 50PFP5332D/37
    Over the past few days, it has been acting up, when i power it on after being off all night, , i hear 1 click, the blue light turns on and in about 3-5 seconds the red like blinks 6 times.
    (i am trying to remember, but when i used to turn it off i remember hearing 2 clikcs, now i only hear 1)
    If i turn it off then turn it right back on, it powers on fine
    What i have to do is unplug the power cord from the back of the TV for about 10 min then plug it back in and it allowed the TV to turn on fine.
    Im sure this wont last forever, and I have been having a rough time finding the service manual for this TV every link i seem to click is dead.
    Anyone have any ideas on what this could be happening? or possible cheap fixes? With the holiday shopping all done, i cant afford a new TV right now, so i would like to keep this one going for a few more months.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: 50" Philips 50PFP5332D/37
    service manual should be this one:
    There are some other threads on here suggesting it's the usual bad caps crap (under a heatsink)
    • BigKyle
      • Dec 2011
      Thanks for that
      i went in to "SAM" mode to check our the error codes, and the error code list is empty...
      i am really confused now /=
        Originally posted by BigKyle
        Thanks for that
        Bad caps won't come under an error code; you'll need to open up your TV.
        • BigKyle
          • Dec 2011
          Even though i get the 6 blinking red lights? i though that the blinking lighters where "reporting" and error code...
            Failed caps could cause a power supply warning code, but in most cases they cause odd power related faults
            • Leebo249
              SA-HD52 1 Default Crosstalk/static after replacing selector switch IC?
              by Leebo249
              Hey,
              A month back I replaced the selector switch IC on my Panasonic SA-HD52 as the radio was still playing when I selected the CD, it did this with the tape and record too.
              Now when I replaced the IC it worked perfectly, no cross talking and I left it at that for a month and have come to it today to play a CD (you can hear it spinning) and the issue has come back although with another issue.
              Both issues are random, the original problem where the radio will play over other playbacks has come back and another time you turn it on it will refuse to play anything,...
              09-07-2025, 07:23 AM
            • pajdek
              Lenovo Y700-17ISK turn on and off
              by pajdek
              Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
              09-20-2023, 02:49 AM
            • ovrax
              Philips 55PUS6804/12 turn on & off (probably backlight issue)
              by ovrax
              First of all, please excuse me as I'm quite new to this field.
              I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
              I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
              The Ambilight works perfectly and stays on.
              No sounds.
              Thanks in advance.
              08-25-2024, 04:33 AM
              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
              I am comparing them to a brand new one that I installed
              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
              I going to let it run for several days before I remount back on the wall next to the...
              09-05-2024, 06:48 PM
            • JohnML1975
              Falcon FF32S53 turns off by itself then will not turn back on unless you wait
              by JohnML1975
              Dear Forum members
              I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
              I will upload some photos and share my trouble shooting steps so far
              07-20-2025, 12:28 AM
