Lg 42pc3d
  • Aquarius89
    • Dec 2011
    • 18
    Lg 42pc3d
    Hey there, I have my beautiful ( but at the moment useless) LG 42". I have studied some of the forums with similar problems in the same model ( No picture, but sound) And heard that the problem could be minor or fairly major. Its important to not that I have ZERO experience, but some mild back ground working on computers ( building them), I was still absolutely lost when i pulled the frame off the back of this beast.
    So, I need some assistance obviously with trouble shooting while I do a Google search for maybe finding some sort of technical manual in PDF format.
  • PlainBill
    • Feb 2009
    • 7034
    Re: Lg 42pc3d
    The service manual can be found at Elektrotanya. It's the second on the list.
    This TV is notorious for failures in the Z-Sustain and the Y-Sustain, commonly the hybrid. The hybrid is expensive ($40) and difficult to remove. There are a number of repair services on eBay, or you may find a new or repaired one available. A failure of the Z-Sustain results in a very dark picture, with a faint image visible at the right side. A failure in the Y-Sustain results n a completely black screen.
    PlainBill
    • Aquarius89
      • Dec 2011
      • 18
      Re: Lg 42pc3d
      I read a another thread that suggested shining a bright LED light at the screen to see if there is any color at all, I attempted this and its completely black, but the screen does "prime" with no picture at all. and this is likely the Z-sus you say? Might I ask the technical level of replacing it.
        Re: Lg 42pc3d
        That's an LCD thing.
        If you have the "prime" glow from the plasma, the Y-sus is quite likely okay. I would say Z-sus. A quick check: Turn on the TV for 30 mins, then turn it off. Feel the heatsinks of the Y-sus and Z-sus. Are either warm?
        Can you post a pic of the Z-sus? There are usually a few fuses on them that can sometimes blow even without a fault.
        • PlainBill
          • Feb 2009
          • 7034
          Re: Lg 42pc3d
          Lose the colors. You really don't want to do anything that makes it difficult to read your posts.
          Replacing the Z-sustain is moderately easy. Four or five mounting screws, 5 connectors (one of which is a pain), and one adjustment to do after installing the replacement. It's a lot easier than pulling the back off- those metal edges are sharp!
          PlainBill
          • muskin
            • Nov 2011
            • 64
            Re: Lg 42pc3d
            If you have a meter you can check the fuses. My z-sustain board blew one of the fuses and I just replaced the board. Pretty simple like Bill said.
            • Grunder
              Sansui SV-EPD-42Q0BP +VS short on Zsustain chip
              by Grunder
              Hi Guys,
              I have a faulty Sansui SV-EPD-42Q0BP plasma television that is faulty.
              Symptom: very dim column of broken picture on right hand side. A column about an eighth of the screen width. the other 7/8 of the screen blank.
              Diagnosed: 1) Capacitors C96 & C100 both 47uf/250v swollen/ ruptured.
              2) Fuse FS152 4A Open circuit.
              3) Pin +VS on Hybrid ic measures 0.8 ohms to Gnd.
              (this is with the pin de-soldered from the pcb.
              4) D96 & D85 on the +VS supply measure ok.
              06-27-2019, 03:14 AM
            • Grunder
              SANSUI PLASMA: Could mains surge damage Zsustain only?
              by Grunder
              Hi Guys,
              I have a Sansui SV-EPD-42QOBP that has a damaged Z SUSTAIN board.
              Is it possible for a mains surge to damage the Z SUSTAIN board only.
              As a rule I dont do plasma tv repairs, but a customer needs a damage report for their insurance broker, so I took it on.
              I do a lot of damage reports on lcds, these range from cracked panels, liquid damage and power surges. In most instances the surge damage is quite evident where you can see damage in the front end of the power supply.
              (these surges appear after a power outage and the power comes...
              06-26-2019, 07:27 AM
            • ronaldopdias
              PS5 EDM-010 - Intermittently Power
              by ronaldopdias
              I received this PS5 for repair, and it’s been quite difficult to diagnose.
              It beeps once and turns off. The power draw goes up to 100W, then drops back to 0.20W. However, if I keep trying to power it on, it eventually turns on and stays on. I can play games without any issues.
              Once it's turned on, I can shut down and power back on normally.
              But if I leave it off for an hour or so, it starts beeping again and shuts down—back to square one.
              I couldn't find any shorts on the board.
              The UART log shows the following:...
              07-02-2025, 04:13 AM
            • edugimeno
              Wine cooler flickers at startup and doesn't cool enough
              by edugimeno
              Hi there!
              I have an old wine bottle cooler, it's a basic peltier cell system with a power supply built in with the controller board, with a simple display at the front door and 2 push buttons to select the desired temperatura.
              Symptoms are it doesn't barely cool down, and makes a chirping noise at the board.
              Both fans on each side of the peltier are (now, after much cleaning) running smooth and silent
              When you turn it on, the front 7-segment display flickers for a variable time, usually like 1 minute but sometimes nothing or 3 minutes... Then turn on solid (but still some...
              03-01-2025, 04:51 AM
            • user546087
              Keyboard backlight too bright - Asus Zenbook S16 / UM5606
              by user546087
              I have a new Asus Zenbook S16, Model UM5606. Unfortunately, the keyboard backlight is too bright, even on the lowest setting. I have explored several ways now:
              - kindly ask Asus for an adjustment - they basically told me to STFU and get lost It is not possible, they say. Of course.
              - tint the keycaps from behind - I have already tried that - it is kind of a last resort
              - try to find out, how it is done, look at schematics - this is, where we are at.
              - maybe get the BIOS modified somehow? This would be the best option but I do not know a lot about...
              02-24-2025, 02:03 AM
