Have VW37L that I can not get the back light to come on. I just installed a new main board. Before I started nothing would work. All I had was a Amber light and after reading a lot of threads on this site and others they all said the main board. When put the new board in the logo changes from Amber to White but the back light does not come on. When you look at the inverter board there is a blue LED which stays lite. Any suggestion on what to check? The fuse is good, I am getting 24volts there.
Vizio vw37l, no back light
Re: Vizio vw37l, no back light
Installed different inverter board that bought on Ebay. Plugged in and now lights up. The Blue LED is not supposed to stay lite. Once the back light is on the Blue LED will go out. If anyone would like to know any voltage readings or anything else let me know before I close it up.
by sam_sam_samThis happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
I am comparing them to a brand new one that I installed
The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
I going to let it run for several days before I remount back on the wall next to the... -
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
Hello everyone. I have a problem with an HP laptop, when connecting the charger the amber light comes on for 6 seconds, changes to white and does not charge, I have checked all the components with the multimeter and the values seem correct, I was guided by the diagram, I do not know if it is a problem with the BQ24728H charge controller, investigating it seems that the voltages given by the charge controller are correct, I made the measurements connected to the power source and without the battery:
- ACN (BQACN) 19.6v
- ACP (BQACP) 19.6v
- CMSRC (BQCMSRC) 19.6v
- ACDRV... -
by x_orange90_xI have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
- Loading...
