Samsung Plasma Tv with black vertical bar.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    Someone has a Samsung plasma tv model#Pn50a400c2dxza with a black
    vertical bar on the right side of the screen from top to bottom, and this tv is
    two years old. Can anyone offer any solution for this problem?
    Re: Samsung Plasma Tv with black vertical bar.
    Usually a bad panel. Sometimes fixable, often not. Would need a picture of the inside of TV to tell.
    • mockingbird
      • Dec 2008
      • 5484
      No, it's not the panel.
      See this video:
      http://www.youtube.com/watch?v=FXy2jHNpv_0
      It is possibly fixable.
        See this video:
        It depends on the design. Some TVs have the X buffers off-panel which are replaceable - whereas others have the X buffers on the panel and replacing them is not possible.
        • mockingbird
          • Dec 2008
          • 5484
          Yea, but as the guy in the video points out, it's not the actual panel, the X Buffers were on the permanent cable coming out of the panel, so it's still not fixable, but there is nothing technically wrong with the panel itself.
            Suppose, but I'd still write the TV off either way, as the panel+cables is going to be very expensive.
            • cadiman
              • Mar 2010
              • 397
              You don`t know if it is a board or the chip on the ribbon cable. I have repaired over a couple hundred tvs so far. I learn something new on each one. Not always pattern failure.
              I have had two plasma tvs with the vertical bar as said above. One was a burned chip on the panel ribbon cable.
              The other had a bad board and a failed chip on the ribbon cable.
              The chip looked ok but when I replaced the faulty board it still had a vertical bar.
              The real problem here is people will make the tv dead (does not power on or blank screen) because everyone knows not to buy or take a tv with a vertical bar unless you need boards.
              The one I have is a samsung and I use it for testing boards and learning.
                In one case I have fixed the black vertical bar problem on an older LG plasma. It was just a resistor on the FFC that had a cold joint and had separated itself from the board. Tapping the bottom of the TV would sometimes fix it, but never for long. Fixed it with a bit of solder and a soldering iron.
                • cadiman
                  • Mar 2010
                  • 397
                  Older is the key word here... as in 2005?
                  I think the older tvs were less of an issue and more repairable. I have a few of the oldie but goodies and I will not part with them.
                  • madphill
                    • Aug 2015
                    I have the exact same issue on a Samsung P59D6500. It's on the far-left from top to bottom. It's approximately 4" wide. The TV got this issue around the 2-year mark and Samsung wouldn't do anything for me.
                    I've taken the back panel off and ensured the ribbon cables along the side of the TV are connected before but don't know if there is much else I can do.
                    Any advice is appreciated.
                      Is the whole bar black, or are there a few pixel lines within the bar?
                      • heyagbay
                        • Jun 2016
                        Sorry old thread, but what difference would this make? I have a Samsung PN51E7000 which started out with a few thin vertical lines. It eventually turned into an entire vertical black bar about 3" wide with the thin vertical lines visible within.
                        I tried removing all ribbon cables going to the bottom (x-buffer?) boards and turning on the TV. The image was just dark noise, but the vertical black bar was still visible. This leads me to believe the problem is the chip on the ribbon cable going to the panel :/
                        In hopes for a cold solder issue, I tried flexing/tapping on the bottom boards, but the black bar remained. Even if it was that bottom board, the ribbon cable from the panel appears soldered or glued and I wouldn't know how to reconnect it.
                        It's pretty frustrating knowing that a little chip going bad can ruin an entire TV.
                        • magister
                          • Feb 2016
                          • 7
                          what does it mean if the black abr shows pixels inside? I have a samsung plasma with that issue. the bar is in the middle, where the two thin boards that control the vertical pixels are hooked together with jumper-wire type of connector. I can add a picture if that helps.
                          • freakaftr8
                            • Oct 2012
                            • 3743
                            Usually a bad panel. Sometimes a bad control board. Check all ribbon cables.
                            • magister
                              • Feb 2016
                              • 7
                              did you have any ideas about this tom66?
                              • magister
                                • Feb 2016
                                • 7
                                im having a similar issue. I have a black bar straight down the center of the tv, and if you were to divide the tv into two equal squares, there is a thin strip right in the middle of the screen within the black bar. I opened the TV up, and the bar is located where there aren't any ribbon cables or anything going right to where the bar is generated on the screen. should I check one of the boards? I will open it up again if yall think its fixable. otherwise ill sell the boards and scrap the screen.
                                I upgraded to the newest firmware and it didnt change anything.
                                also the first time i turned the tv on after closing the back, I saw many green and red vertical lines for a split second during boot, right as it was pulling up the video input. I can't get the tv to show them again, so I dont have a picture.
                                model is pn50a450p1d.
                                thanks for any assistance. I bought this TV for cheap as-is, so i wont be distraught if its not fixable.
                                • magister
                                  • Feb 2016
                                  • 7
                                  also that colored vertical line in the very center of the screen is there from the moment I hit the power button. so...dead panel, right?
                                  • heavymachines
                                    • Mar 2011
                                    • 1028
                                    Have you tried reseating all ribbons and cables? With power off and disconnected with 30 second drain time when you do the reseating.
                                    • magister
                                      • Feb 2016
                                      • 7
                                      I will try tonight. I didnt do every cable, just the ones closest to the bar's area of the screen.
                                      • freakaftr8
                                        • Oct 2012
                                        • 3743
                                        Yes
                                          09-07-2024, 05:50 AM
                                        • thetonywarren
                                          Samsung PN51E450 Plasma Vertical Lines
                                          by thetonywarren
                                          Friend of mine has a Samsung Plasma panel with some vertical lines that are starting to form on the screen.....Ive never worked on a plasma panel, so Im not sure what to look for, would this typically be a main board issue, or something else?
                                          Any help would be appreciated.....Please let me know.......
                                          02-14-2022, 01:23 PM
                                        • afex
                                          Samsung Plasma TV with vertical lines (model PN50B430P2D)
                                          by afex
                                          This is my 2nd broken TV I'm trying to fix and haven't been able to figure out... currently going without any working TVs so am hoping to be able to fix one..
                                          This Samsung PN50B430P2D Plasma has this big block of vertical lines which will fade in shortly after turning the TV on. The lines will sometimes flicker a bit or fade in/out and sometimes it just stays present. The length of time it takes them to appear varies, sometimes its a few minutes and other times it appears immediately after powering on.
                                          I have attached an image of the TV with these bars displaying....
                                          11-08-2021, 09:23 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                          09-06-2024, 11:40 PM
