samsung PS42C450B1WXXU
    Re: samsung PS42C450B1WXXU
    Just an overall shot of the bottom of the board.
    I think you probably got a dud board, but I'm not sure. If you have a scope, you could test the scan voltages.
    • lakey35
      • Nov 2011
      • 25
      There you go.
        No - bottom of the board. Usually green.
        • lakey35
          • Nov 2011
          • 25
          Is this what you mean?
          • lakey35
            • Nov 2011
            • 25
            have just checked Va and Vs again on power board while Y board is out of tv and voltages are holding now.
            So am looking at replacing Y board again.
              Yes. I've highlighted some components.
              Blue circled components = probably diodes. Use your meter on the diode range. Check them one way, and the other. You should get ~0.5V one way, and infinite the other.
              Red circled components = Check all pairs of two pins for short circuits using the ohm range. You should find no continuity between any two pins.
              • lakey35
                • Nov 2011
                • 25
                #27
                d5004 441 both ways
                d5003 441 both ways
                tested with diode range
                q5003 short
                q5007 short
                q5008 short
                tested with ohm range
                  Originally posted by lakey35
                  d5004 441 both ways
                  d5003 441 both ways
                  q5003 short
                  q5007 short
                  q5008 short
                  Are those all the transistors? It would be strange for all to be shorted. Could you list which pins are shorted? (Typically drain-source shorts, or drain-gate.)
                  441 both ways indicates a problem with measuring in circuit.
                  You may have to desolder each MOSFET and test it individually.
                  Or you could send the board back as faulty as it looks a lot like it is.
                  • lakey35
                    • Nov 2011
                    • 25
                    #29
                    I will desolder the components tomorrow and test them again, but I have been offered another tested board for £15 so will buy that and see what happens.
                    Can the buffers blow the new board or should it be ok?
                      Yes, a bad buffer can damage a Y board.
                      I would advise you change both at the same time as the buffers may be causing all of your problems. Seems to be the only part you haven't yet changed!
                      • lakey35
                        • Nov 2011
                        • 25
                        #31
                        I have changed them aswell though lol. Managed to get a full set of boards for it but they were untested but for £60 the lot was worth the gamble lol
                        • lakey35
                          • Nov 2011
                          • 25
                          #32
                          Is there anyway I can test the y buffer board without connecting it to the y board?
                          The buffer boards i have are both pcb no:LJ41-08594A.
                          Have got the new y board but dont want to risk blowing it without testing the buffers.
                          Thanks guys
                            Thanks guys
                            Post a picture of the board - a multimeter ohm test can find most (but not all) failures.
                            • lakey35
                              • Nov 2011
                              • 25
                              #34
                              heres a pic of the board
                              Had to get one of net cause camera battery died but is the same board
                              • lakey35
                                • Nov 2011
                                • 25
                                #35
                                i know the pin out of the far right top connector is
                                1:gnd
                                2:gnd
                                3:reset
                                4:5v outl
                                5:gnd
                                6:gnd
                                7:le-2
                                8:oc2-a-2
                                9:oc2-b-2
                                10:os1-2
                                11:clk-2
                                12:gnd
                                pin1 is on the right
                                  Plug buffer into sustain board.
                                  Connect sustain board power.
                                  DO NOT TURN ON TV!
                                  Test resistance between each red arrow (any pin) and ground.
                                  Actually, can post a close up pic of the connector on your board? I can't see if the sustain voltage is on those pins or if they are data signals.
                                  • lakey35
                                    • Nov 2011
                                    • 25
                                    #37
                                    far right connector
                                    middle connector
                                    left connector
                                      Okay, test this pin to TV's case, whilst connected but not turned on.
                                      Then can you get a picture of the bottom of the buffer board?
                                      • lakey35
                                        • Nov 2011
                                        • 25
                                        #39
                                        have tested that pin and i get o/c is that correct?
                                          That's fine. Can you post a pic of each connector and both sides of the board?
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                            09-07-2024, 05:50 AM
