I have a Polaroid FLM-3732 LCD tv. The problem started with no picture or sound, just black screen. I replaced the main board with a board that did not have the exact part numbers as the one in the tv. The board looked exactly the same, just a few numbers off. Could not find one with the exact numbers. After I put the replacement board in the picture and sound returned.Yahoo!!! Now the picture is very washed out and color crazy. I'm wondering if this is the result of the wrong main board or is there something else wrong. Like the T-con board? Any suggestions. Thanks, Scott
Polaroid FLM-3732 scrambled picture
Re: Polaroid FLM-3732 scrambled picture
What you are seeing is due to the board being mis-matched to the panel. It is possible that there is some setting(s) in the NVRam adjustments that would take care of it, but it is not extremely likely. Chances are you will either need to obtain the correct baord, or replace the LCD Panel too.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by ermalsHi all!
I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
3. I've checked voltages... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... - Loading...
