AOC Envision LE24H067 Wont turn on at all
+ More Options
Posts
    Re: AOC Envision LE24H067 Wont turn on at all
    Originally posted by kaks
    So why am i not getting any Standby light when i plug the tv to the wall? if i press the volume channel keys there is power. the only thing it does is that it blinks as soon as i plug it in to the wall.
    See above.
    The fact that you get a brief standby light is encouraging. Usually a bad main board causes either no standby, or permanent standby, or sometimes the TV will exit standby (e.g. with a blue LED) but will stay there and will not turn off or show a picture.
    • kaks
      • Nov 2011
      • 25
      i wrote it before i saw you response sorry ok i will upload the pics thankyou
      • kaks
        • Nov 2011
        • 25
        OK hear is the pic of the switch board
        i did a little test i disconnected the switch board and tried using the remote to turn on the tv. i measured the voltage on the IR pin and the voltage varies everytime i press any key on the controller. the voltage varies even hen i press the the power button. the voltage on IR pin reads 3.3v
          Okay thanks for the pic.
          Interesting that they would go for a surface mount design... is a bit more expensive than a through hole button board.
          Anyway - To test the POWER button. Just try pressing it. Compare it to the others. Does it feel different? Does it get stuck down?
          If the button feels good, another test is necessary. Using your multimeter, check the continuity of the pin I have highlighted to ground, both when depressed and when not. You may need an assistant. There is a hole called GND1, which you could use to put the black probe, then you would need a red probe on the pin highlighted and a finger to press the switch. The board *should not* be plugged in during this test. If you don't know how to test for continuity, make sure to ask first... post a picture of your multimeter too so we can see what setting to put it on.
          If the value changes, then the button board can be ruled out for now.
          Note - it's 10pm here so I'm going to bed soon. But there are many other people on this forum who can guide you through this...
          • kaks
            • Nov 2011
            • 25
            I tested for continuity and yes the power button should be fine I used the diode tester mode on my multimeter I head sound everytime i pressed the pwr switch . i also tested the othe switches and they are all fine. What should be my next step please Thank you
            • kaks
              • Nov 2011
              • 25
              #26
              Ok i tested the voltage of the PWR pin on the main logic video board and when i press the power switch the voltage goes from 3.3v to 0v just a note thanks
              • kaks
                • Nov 2011
                • 25
                #27
                Ok so acording to my general understanding I get power all the way to the PWR but when I press the PWR button THe signal to start the tv does not get send. What could be the problem that that signal doesnt get trought?
                  Okay switch board is good.
                  Next, some components on the main board need testing.
                  For each red component: I suspect these are LDOs or voltage regulators. Attach the black lead of the meter to an exposed metal portion of the case, excluding any heatsinks on the power supply. While the power is applied to the TV, test each pin and note down the voltage. There is usually a designator next to each component, such as U702; use this to refer to each component. There is no need to test the middle pin which is cut off. Note the part number e.g. "AP1117-33" which is on the LDO.
                  Confirm whether the component on the top right of the board which looks similar to the left red circled component has a designator beginning with "U". If so, that will need testing too.
                  For the blue circled diode: With the set *OFF*, use the diode test on your multimeter. Test both ways. You should get about 150 - 500 one way (or 0.150-0.500, depending on how your meter displays it) and 0L or "1." (or open) the other way. If not the diode is dud.
                  For each green component. These are inductors. First, with the TV unplugged, test for continuity (only necessary to test one way.) You should get a beep or dead short, or very low resistance. Next, with the TV plugged in, test the voltage on each exposed pin of each inductor. One end will measure 0V or some random value. The other end should measure a fixed, low and stable voltage. Note the voltage here. There is probably an identifier like "L123" next to each of these; use this.
                  Good night and happy testing...!
                  If any of these shows bad, you have a choice. You can replace it, but it will require a skilled hand at soldering. Or, you can replace the main board, *if* you can find a replacement.
                  • kaks
                    • Nov 2011
                    • 25
                    #29
                    hello i will do the testing as of to best of my knowledge I really apreciate your help thank you very much.
                    • kaks
                      • Nov 2011
                      • 25
                      #30
                      Ok i tested the diode you circuled blue and i get a reading of 158 one way and 1974 the other way around so acording to my understanding this diode is shorted?
                        It's probably okay; most likely the circuit is interfering with the measurement. Shorted is a reading less than about 50, and the same both ways.
                        • kaks
                          • Nov 2011
                          • 25
                          #32
                          ok the inductor have a voltage on both pins
                          the diode is fine as you said
                          the voltage regulators only the leg #3 of each regulator carries voltage
                          • kaks
                            • Nov 2011
                            • 25
                            #33
                            U708 carries 9.1v
                            U703 carries 5v
                            U702 carries 3.3v
                            • kaks
                              • Nov 2011
                              • 25
                              #34
                              Hello testing the inductors i get voltage both ways.
                              the 2 small ones have a low voltage like 2.3 and 3v and 5v and 4 on both sides
                              the biger inductor on the very top has a kind of high voltahe of aroun 9v one pin and 10v the other pin.
                              the gray inductor has a voltage of like 1.3 one pin and the other pin has like 2v
                              is this normal? you stated one side should have 0v on the inductors
                                The values you are seeing are not what I expect but I am probably incorrect in assuming how this design works. If there's a voltage it's probably okay.
                                I don't really know what to suggest any more - is there a part number on the board? Some replacement boards are cheap. Others are expensive, it depends on the board. Then again a 24" LED TV is not a bad find, even if the board is £50 or so to replace.
                                • kaks
                                  • Nov 2011
                                  • 25
                                  #36
                                  hello where could be a good place to find Boards.
                                  Also i want to make sure it is the main board?
                                  according to what we have done do you really think its the board?
                                  or could it be the LED laps?
                                  could it still be the power board? I called AOC Envision and they can sale me the board for $102 usd
                                  what do you suggest me to do?
                                  I will post the pics of the main board as asoon as i get home from work
                                    eBay is a good source, boards are usually pulled from broken TVs. (e.g. cracked screen.)
                                    LEDs are very likely to be fine. They rarely fail. And besides, you have no audio, and the unit does not exit standby.
                                    $102 is a rip off for a power board, and the power board is not the faulty board, as far as has been determined.
                                    • kaks
                                      • Nov 2011
                                      • 25
                                      #38
                                      This are the numbers printed on the main video board
                                      715G3759-MOF-000-005K is this the model number?
                                      this is another number thats on a label on the board
                                      (T)TQACB ZKD3502 TOP:A MB:A
                                      S/N:1526730M0843 V2.02
                                      • retiredcaps
                                        • Apr 2010
                                        • 9271
                                        #39
                                        Especially, when a brand new TV is $159.
                                        http://electronics.pricegrabber.com/...803065429.html
                                        --- begin sig file ---
                                        --- end sig file ---
                                        • kaks
                                          • Nov 2011
                                          • 25
                                          #40
                                          jajajajaja thats wright well guess im just going to have to give up on this junk i think its going directly to the trashcan jajajajaj
                                          • dj8452000
                                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                            by dj8452000
                                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                            02-18-2025, 08:28 AM
                                          • trex66
                                            Craftsman 82345 Multimeter broke!
                                            by trex66
                                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                            03-04-2025, 04:26 PM
                                          • Sofian75
                                            Things not to do with a multimeter?
                                            by Sofian75
                                            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                            I fixed some of them and some I ve made things worse by blowing components.
                                            Every time while taking measurements with my multimeter.
                                            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                            So my question is are there things I should not do with my multimeter?
                                            Or measurements I should do only with the charger and battery unplugged?...
                                            06-27-2024, 05:13 AM
                                          • max_smart
                                            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                            by max_smart
                                            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                            06-01-2024, 03:27 PM
                                          • DrDos
                                            Wierd reading on my multimeter
                                            by DrDos
                                            I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
                                            09-12-2025, 04:44 PM
