MAGNAVOX no picture powers LED 47MF437B/37
    Re: MAGNAVOX no picture powers LED 47MF437B/37
    In circuit measurements are never guaranteed to be accurate -- if they test good out of circuit they're probably good.
    • c.teaman
      • Feb 2013
      • 20
      Thanks for the reply. Where should I look next to repair my tv? After replacing all of the caps, it still wont power up and I still get the chirping. The ZD diodes referred to earlier in this thread all test fine...
        When you say they test fine, what do you read?
        • c.teaman
          • Feb 2013
          • 20
          between 450-550 on each, infite (1) backwards...
          • c.teaman
            • Feb 2013
            • 20
            I have spares for some of them, would it do any good to just throw them in?
              Those readings look good. The other possibility is a bad startup cap. This is a small capacitor on the primary side of the supply, normally near the controller IC.
              • c.teaman
                • Feb 2013
                • 20
                Thank you very much, I'll replace that and see what happens. Would anybody be able to pinpoint it's location for me? I would upload a picture of my own, but my camera isn't nice enough. Would it be possible to show where it is on one the pictures already on this thread?
                  Assuming it is this board.
                  https://www.badcaps.net/forum/attach...2&d=1321230837
                  Your startup caps are indicated below, replace all of them.
                  • c.teaman
                    • Feb 2013
                    • 20
                    Thanks so much, I really appreciate it
                      Diagram
                      • c.teaman
                        • Feb 2013
                        • 20
                        I'm sorry to keep asking questions... is it acceptable to replace a 6.8 uF/50V cap with a 6.8uF/35V? I'm removing the capXon and replacing it with a rubycon
                          Depends where it is. If it is a startup cap probably OK but that's not a general rule.
                          • c.teaman
                            • Feb 2013
                            • 20
                            So, I have now replaced every cap on the board... it still chirps and won't power on. The only thing that seems to indicate a problem is the three diodes that show bad numbers in the circuit. All three test fine out of the board. Any ideas? And am I damaging the caps I have just put in when I test it?
                              What are the designators of the the diode so you can look at the diagram to see how they are being used in the circuits?
                              • c.teaman
                                • Feb 2013
                                • 20
                                D912 0.001, 0.001
                                D926 0.365, 1.755 and climbing
                                D928 0.355, 1.755 and climbing
                                the last two are located right by the three 1500 uF caps
                                  Can you highlight D912 for us -- looks bad...
                                  • c.teaman
                                    • Feb 2013
                                    • 20
                                    D912 tested fine when it was out of the board... .560, 1.0
                                    I also noticed that Scatman was getting the same exact readings on D912 and it ended being resolved for him when he replaced zd902 & zd904. They were both completely destroyed... mine are functional.
                                      Perhaps it is best to replace them, as it has almost always proved to be the issue with these TVs.
                                      • c.teaman
                                        • Feb 2013
                                        • 20
                                        Ok, I'm stuck... I'm just going to run through real quick what I've done... hopefully someone knows something I'm not finding.
                                        All electrolytic caps replaced. All of them.
                                        Fuse continuity test. Good to go
                                        Replaced ZD902 and ZD904.
                                        D912 0.001, 0.001 in circuit; but test normal outside circuit.
                                        D926 0.365, 1.755 and climbing in circuit, normal outside circuit.
                                        D928 0.355, 1.755 and climbing in circuit, normal outside circuit.
                                        No progress. When plugged in, the red light comes on. Upon pressing the on button, it turns green and chirps. After about 5 seconds, the green light goes out, turns back to red, and the chirping continues.
                                        Now what? Do I need to check out Q901? I'm not ever sure I know how to test it... I think its a MOSFET. I only have my DMM.
                                        Anything input would be greatly appreciated. Thanks for all your help thus far, tom66
                                          OK, as I had suggested to look at the SCH I provided, you will see that D912 is connected in parallel with SOURCE resistor R949 0.1 Ohm, so it will show like short on the board.
                                          D926, 928 are connected in parallel with Source/Drain of MOSFET Q917, so if the pads where the D926/928 are connected to still show short, then Q917 is shorted.
                                          • csmith
                                            Vizio D50u-D1 Powers up no picture
                                            by csmith
                                            I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                            Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                            supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                            issue. Set will power up with remote but not power off....
                                            07-11-2025, 11:52 AM
                                          • sergio_av
                                            Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                                            by sergio_av
                                            Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                                            Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                                            When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                                            Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                                            01-01-2025, 05:27 PM
                                          • KYBOSH
                                            Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                                            by KYBOSH
                                            Saved this beast from the landfill this weekend.
                                            Manfactured July 2013 in Mexico.
                                            I love working on plasma TVs.
                                            Its been a while but I was lucky enough to find 2 this week.
                                            The TV powers on and stays on but no picture. Havent checked for sound yet.
                                            No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                                            Will start troubleshooting tonight.
                                            10-17-2024, 01:17 PM
                                          • Tr0ll
                                            by Tr0ll
                                            Original T-con:
                                            First replacement T-con:
                                            10-07-2023, 07:48 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
