Got this set free from my sister.
Problem, doesn't start with sound. Especially when cold.
Does not read DVD, screen menu ok.
FIXEs were..
Sound:
Never found the real reason or the broken Caps, diodes etc. ..thought it might be a software timer
Showed some fast digital spikes on my scope to earth on Digital amplifier processors wakeup line! So check that with scope. Find the digital amp signal processor datasheet and I found the info there.
wake up Signal goes from main board to power board and from there to the end amplifier boards signal processor. Somewhere between happened strange things and there was intermitted signals going to ground! REally like digital 0, so the wakeup time for amplifiers processor unit was never reached on the wakeup line..
I ended up adding a 100uf electrolyte to this line to take off /ditch the spikes. Worked fine since. If remember correctly did not work everytime with 47uf. Processor needs above 3.3V low logic level wakeup signal and there is a time limit for it.
If the thing some day does not play sound, I will probably find the intermitted annoying fault afterwards when the responsible component(processor?) has gone to electrical heaven 100%.
IF you know the real component that affects this, let me know. The wakeup circuitry was rather complex tho..
For now I think it's a software timer..(might be also a component timer
DVD:
Cleaned laser head with Polypropylene alcohol..so safe for plastics. Never missed a beat since that day..
Hope this helps someone..this works for all DVD players that won' t read the disk and the laser head is ok.
PS: Cleaning with lens clotch etc. will not work. you have to use the real stuff for the laser head.
FIXEs were..
Sound:
.Showed some fast digital spikes on my scope to earth on Digital amplifier processors wakeup line! So check that with scope. Find the digital amp signal processor datasheet and I found the info there.
DVD:
