VIZIO 26" - VIT70063.50 Inverter Board F1 Fuse
  • richr69
    • Jul 2010
    • 58
    Need help finding a replacement SMD fuse which appears to be OPEN on the VIZIO Inverter board VIT70063.50. The only marking on the fuse is 20, and the markings next to the fuse is 1A/76V. The dimensions are 3.34mm x 1.6mm and is 1.16mm thick. I did a quick search on Digi-Key but could not find a exact match with respect to the voltage. I'm not sure what would be a good replacement. Any thoughts??
    Thanks.
  • PlainBill
    • Feb 2009
    • 7034
    Re: VIZIO 26" - VIT70063.50 Inverter Board F1 Fuse
    Thanks.
    I'd go with Digikey 507-1077-1-ND. It's rated for 125 volts, but a higher voltage is not a problem.
    PlainBill
    • richr69
      • Jul 2010
      • 58
      Hi PlainBill,
      So the original voltage i.e. 76V, is assumed to be AC and not DC? The reason I ask is the Digikey part 507-1077-1-ND is rated at 125VAC/63VDC. I did not realize that.
      • PlainBill
        • Feb 2009
        • 7034
        Hi PlainBill,
        I have no idea if the voltage on the original is AC or DC, but I can make some assumptions based on my experience.
        1. I have never seen a backlight inverter powered by AC.
        2. I have never seen an inverter powered by any voltage greater than 24VDC (but I DID see a schematic that indicated jumper positions for a 48VDC inverter supply.)
        3. An inverter presents a capacitive load to the power supply. Thus a sudden interruption in voltage will not create an inductive spike.
        4. The voltage rating of a fuse is the maximum voltage the fuse can interrupt. Going with a higher voltage fuse never presents a problem (provided physical dimensions are the same).
        PlainBill
        • richr69
          • Jul 2010
          • 58
          Hi PlainBill,
          Based on your assumptions, are you suggesting that the part you recommended, which is rated at 63Vdc, is adequete even though the original fuse is specified as 1A/76V?
          Just want to make sure I understand.
          • PlainBill
            • Feb 2009
            • 7034
            Hi PlainBill,
            Yes.
            PlainBill
            • richr69
              • Jul 2010
              • 58
              Replaced the fuse (finally) and the TV is working. Thanks PlainBill for the help.
                Almost a year later. What happened? Fuse get lost in the post?
                • DavidOH
                  • May 2012
                  • 105
                  I know this is an old thread. But I wanted to say Thank You for the info on here and two other threads I found with google. I fixed a RCA L26HD35D with no picture. The F1 fuse 1A 76V was bad. I replaced it with a PICO 1A 125V fuse from a x-main I have. The set is fixed and on it's way back to the owner. I really like this forum. Thank You.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • Hakuu
                    by Hakuu
                    Hi There,
                    More Details
                    TV Model - LG OLED77G1PUA
                    07-12-2023, 02:37 PM
                  • canadaboy25
                    Panasonic TC-P54VT25 No image. A or D board?
                    by canadaboy25
                    I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                    I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                    01-17-2021, 01:06 AM
