samsung pn50a400c2d volume remot problems
  • cookiemonster131
    • Oct 2011
    okay i have searched all over the internet and for one you guys know your stuff and 2 i cannot find a definetive answer.
    here is the scenario, all of the sudden my 4 year old tv, samsung pn50a400c2d turned itself down to 0 and is holding it because the volume bar will no disappear. sometimes it goes away in a minute sometimes an hour. it does not change if you turn off the tv or even unplug it. when you turn it back on it is still volume bar on and if you turn it up it just rocks between 0-1.
    problem 2 is that the remote when this is happening does not always work, i have done the camera check and the remote is working and has NEW batteries in it. also the blue light on the TV flashes to show it gets signal but it does nothing.... again same time frame for it to stop working and start working again....
    so i am not scared to take the the TV apart but i am trying to figure out which board would control these problems. as best i can tell from ym research is that it is the A/V main board with the connectors for input and output on it or the logic board.
    can someone please point me in the right direction?
    Thanks in advance for your help!
    Re: samsung pn50a400c2d volume remot problems
    Actually, you're most likely dealing with a problem with the side button board. It's behind the buttons or touch panel of the TV. It sometimes combines the sensor on the board too. You can either try cleaning it (sounds like a bit of dirt is stuck in the volume down button) or getting a new one, they're fairly cheap.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      +1
      common issue is glass cleaner getting inside.
      • cookiemonster131
        • Oct 2011
        thanks guys for the help, does anyone have a source for one, in case it needs to be replaced. i do not see any on ebay right now.....
        i will try cleaning it tonight!
          You'll need the part number written on the board.
          • randtek
            • Oct 2011
            • 280
            • US
            A quick check you can make to see if that board will fix your problem, is to disconnect one ond of tha cable going between that board and the main board. You can disconnect it from either end. If the volume bar goes away, you know that board will fix yoru problem.
            • cookiemonster131
              • Oct 2011
              randtek i didnt see your post but that was my thought process. i took it apart today and disconnected it as i do not use the side buttons. Sure enough we are back in buisness, THANKS GUYS!!!!!
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
                09-07-2024, 05:50 AM
