50" LG sus problems??
  • gaza007
    • Sep 2011
    • 38
    Hello, Firstly, can I just add that before anyone get's too technical I'm a relatively handy person but no expert 'like yourselves' So if anyone would like to help please bare this in mind..
    My Mother and Father-in-law have a 50" LG Plasma tv, model number LG50PC1D. It went off a little while ago and so they bought a new one, I asked if I could have this to try and fix and heh presto.. here we are!
    The tv had a type of crystal pattern when turning on and the snow effect was flashing on and off and it had vertical lines randomly placing themselves on the screen.. I opened the back up and found the powerboard to have 9 caps which were blown, at that point I got the feeling it was a cheap repair .. However! After replacing all the bad caps with the more expensive Panasonic type, I switched the TV on and there was no change whatsoever..
    At which point I was a little stumped.. After a bit of research 'mainly from this site' I tracked it down to what I believed was the Y sustain board. After being a complete idiot I bought a 2nd hand one from a reputable electronics dealer on ebay. I have just fitted it tonight and the crystal problem along with the flashing snow has gone, but , the vertical line which moves only 3 segments from left to right then back to the start again is more prominant. I have tried adusting the ramp up/down and this made the picture certainly more clear but did not change the vertical line.
    After reading a little more about the Tv I have, some people say that because the X sustain board get's power from the Y it may have blown something in the X ?? Normally this is not the case as the X is totally seperate from the Y but not on this model TV..
    Any ideas??
    Please rember, if you ask me to try anything I'm a novice compared to you!
  • gaza007
    • Sep 2011
    • 38
    Re: 50" LG sus problems??
    Pictures left to right..
    1. The vertical line that goes the to the 3 segment then returns back to the left hand side of the screen.
    2. The back of the Tv .. LOL
    3. The X sus board.
    4. The Y sus board.
    • gaza007
      • Sep 2011
      • 38
      You'll notice on the shot of the back of the Tv that there is a lead running from the Y sus board (left hand side) to the X sus board (right hand side). It runs just above the cooling fan.
        I think you are getting the X-main and Z-sustain confused; there is no such thing as an X-sustain. Samsung call the board an X-main. LG and a few others call it a Z-sustain. But whatever it is, usually a failed Z-sustain just causes a loss of brightness and maldischarge (very dark pixels on certain parts of the display, almost like looking through a fog.)
        Looks more like a Y-sustain failure or possibly an X buffer board failure. Note the X buffer boards are NOT driven by the X-main/Z-sustain or the Y-sustain.
        Often with these cheaper LG sets, the failure of the Y-sustain kills the buffers. The Z-sustain is rarely damaged by a Y-sustain failure.
        Q: Does the white bar move about the screen randomly or is it fixed?
        • gaza007
          • Sep 2011
          • 38
          Hi Tom thank you for the reply.
          I could be wrong with the names it's just what I've seen others describe them as.
          The white vertical line goes in the 3 different positions like a traffic light system, so it isn't permanent in any one fixed position but does have a set pattern to where it goes to next.
          Are the buffer boards repairable or will I have to buy new ones? Cold it be old solder joints?
          Thanks again.
            Thanks again.
            Sometimes a bad Y-sustain kills the Y buffers, so you could be looking at new Y buffers. The X buffers may be okay.
            I am not very good with plasmas so I will ask someone else to verify my diagnosis.
            • PlainBill
              • Feb 2009
              • 7034
              What do you get when you hit the 'Menu' button?
              Have you tried hooking it up to an audio / video source and stepping through the inputs?
              PlainBill
              • gaza007
                • Sep 2011
                • 38
                I'll try now Bill. I hadn't even put a source to it before now as couldn't even get the normal sure effect interference.
                • gaza007
                  • Sep 2011
                  • 38
                  Hi, No picture coming from any source and no menu/volume or programme info while pressing the relevant buttons.
                  When pressing the source button it seems to affect the vertical bars and their position. on the screen. They have also started to go all the way across in segments rather than just the left hand side portion of the tv..
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Eureka!!! Google LG 50pc1dr Troubleshooting manual. It's available on both scribd and Elektrotanya.
                    Of particular interest is page 45. By unplugging the LVDS cable from the logic board and placing a jumper across P1 it will generate a test pattern.
                    PlainBill
                    • gaza007
                      • Sep 2011
                      • 38
                      Thanks Bill. There are two pictures which look like the problems I'm ' having, one referring to the control board 'as you suggested' and the other to a connection between the y board and the buffer. I've checked this connection and can't see any problems at all..but this connection produces the waves so s ems like a possibilit.. I'm now trying to get to control panel but have noticed only 1 green led light on instead of around 4, so I'm presuming the control board is bust..
                      • PlainBill
                        • Feb 2009
                        • 7034
                        Not the control panel, the main logic card. And it seems to be readily accessible. See attachment.
                        PlainBill
                        • gaza007
                          • Sep 2011
                          • 38
                          I thought that was the control board! heh heh. I'm going to take it out today when the kids are out of the way and get one ordered..
                          • gaza007
                            • Sep 2011
                            • 38
                            I meant to ask... Would the Logic board create the TV to look as it does on pg59 of that trouble shooting manual?? It's the 2nd picture from the left.
                            • PlainBill
                              • Feb 2009
                              • 7034
                              Something doesn't make sense to me; however I've never worked with this particular model plasma TV. I'd suggest you wait for others to chime in before ordering anything.
                              The picture you identified corresponds to a bad connection between the Y-Sustain and the upper buffer. At first glance, it looks to me like it is a bad Z-Sustain, however LG built this panel and should certainly know how it works. I'd look very carefully at the cable connected to P3, and the areas of the Y-Sustain and upper Y-buffer where it connects.
                              PlainBill
                              • gaza007
                                • Sep 2011
                                • 38
                                Seems strange also why there should have been so many bad caps on the power board.. Could this have led to failure somewhere perhaps??
                                • mopenstein
                                  Looking for Vertical IC for RCA Chassis CTC159L CRT
                                  by mopenstein
                                  I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                                  Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                                  I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                                  09-24-2023, 10:41 AM
                                • pc_okay
                                  Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                  by pc_okay
                                  Hello friends,
                                  Its been a while, i wish you an happy new year 2025 !
                                  I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                  Laptop take 0.11A.
                                  All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                  I get no oscilation on XTAL 32.768 KHZ
                                  Battery is not charging but charging led is here.
                                  PCH heat at 30° approximatively. (with no heatsink)
                                  I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                  It's a 2 pins Crystal.
                                  01-13-2025, 09:26 AM
                                • pni
                                  LG 49uf695v vertical coloured lines
                                  by pni
                                  Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                                  11-14-2025, 03:15 AM
                                • Stanley1843
                                  Screen Display Vertical Multicolor Lines
                                  by Stanley1843
                                  Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                  06-29-2024, 11:54 AM
                                • jean luc ferre
                                  laptop hp g72 b52sf screen problems
                                  by jean luc ferre
                                  on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                  the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                  i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                  i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                  06-07-2025, 03:27 PM
