17PW26 etc.!
    17PW26 etc.!
    These Vestel PSUs are the spawn of the devil. I have three and NONE of them work properly.
    Also go under the name of 17PW22, 17PW15, but they are all very similar.
    Some things to look out for:
    Dead standby Main filter cap measures good (~320V?) If so check diode D823 next to stby trafo. Can go s/c both ways 0.001V. Measures 0.52V good. Probably silicon. No filter cap voltage? Check fuse F800, PFC fet Q803, PFC diode D824, and bridge rect D800. Check stby controller IC806 and caps C801, C892. Check IC829 78L05. Check IC825 dual schottky rectifier (on back of board, looks like a DPAK.)
    Standby but no run power Replacing C877/C878 (large poly caps near big trafo) is always a good idea. Also try replacing C801, C892 near standby controller (these actually filter some kind of run signal, for some reason they are over here.) Check IC807 (big DIP next to heatsink) supply and shutdown pin. Any ticking/clicking sound? Check for shorted FETs along secondary heatsink and try running without load. Check D845/D846 for shorts. Check power is getting to SG2525A if not check R897. Check SMD R817, R818, R819 on back of board, each should measure 620k.
    Flashing LED Check stby rails (5V & 3.3V) and replace 78L05, and two 4700u 6.3V caps C857, C818.
    Powers up but switches off after several mins, or backlight flickers Check PFC bus is at ~395V if not check PFC ctrl and IC828 the freestanding TO220 LM317T, should have 1.25V between adj/out. Also monitor 24V during flickering.
    Intermittent startup Caps C835, C834, C840, C826 and PFC circuit see above.
    Low rails Check optos and secondary caps. Check PFC. Check for s/c on any rails.
    Doesn't tune into many Freeview signals, weak or blocky picture, weak analogue signal Check R878 and D821. D821 is a 33V zener and with resistor, generates Tuner/IF bias voltage of +33V. Leaky/open zener causes too high or too low 33V which will cause picture problems.
    These are the hints I have gathered so far on these power supplies, I hope they help someone else!
  • abdekader
    • Jul 2014
    • 73
    • Turkey
    Re: 17PW26 etc.!
    thank you tom , i want the same this for 17pw25-4 please
    Electronic Engineer from Syria,Aleppo
    • Clydeuk
      • Jan 2012
      • 193
      Re: 17PW26 etc.!
      I've got a problem with one of these myself, using the 17PW26-1 PSU. There is a fault on the main board i.e. U114 flash i.c was corrupted, I have replaced the i.c but don't have the software for it so no DVB operation. However I don't know for sure but it may have been caused by the PSU, which is quite noisy in operation (like a hissing). I replaced a few capacitors, the remainder check fine for ESR and none are visibly bulging. When the PFC is in operation I'm only reading 375v across the big capacitor (sorry don't remember it's location but you know what I mean), and this coincides with the hissing noise. The set functions on analogue inputs (SCART etc.) however when I put it to standby the blue LED starts to flash and the only way to get it back on is disconnect the mains then reconnect.
      I'm unsure if my DVB fault is the cause of this or if it's the Power supply, the PFC output seems a bit low.
      • dreico33
        TL866 II Plus Check ID Error on various IC
        by dreico33
        Hellow guys , i really need your help here.
        Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
        11-04-2024, 03:13 PM
      • hasel17
        CH341a can erase and read but can't write and blank check
        by hasel17
        So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
        Code:
        Checking for blank...
        (Press
        10-26-2023, 06:20 AM
      • zlr8r
        Hp Zbook Firefly 14 G10 - corrupted Bios's ? - please check
        by zlr8r
        Greetings
        I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
        Serial Number: 5CG3202C16
        Product #/SKU: 739P0AV
        CT Number: PRTUE00WBI30YX
        Description: HP ZBook Firefly 14 inch G10
        BuildID: 23WWWGAZ602#SABU#DABU
        Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
        MAC address not found.
        • I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
        10-28-2025, 01:56 PM
      • Bogdan Kolybaba
        Dell AC adapter - 1 wire protocol. How to initiate to check if adapter works.
        by Bogdan Kolybaba
        Hi all. Trying to troubleshoot issues with the Dell Laptop power supply (a lot of info here). Now I am waiting for a DC power Jack, as there is a loose contact. Want to check if the ID line of the adapter works - I have given abt 3.2 V to this line through the voltage divider, but can't see any signal on the oscilloscope. Same with the 100500% working AC adapter as well. How to initiate 1-Wire protocol transmission? As I understand, the circuit in the AC adapter should send a package for a while as soon as the supply comes to the SPID line. How to initiate this transmission correctly without...
        02-20-2024, 07:41 PM
      • Kinshir
        How to check Dell BIOS dump integrity after downloading from chip
        by Kinshir
        Is there any known way to check Dell BIOS dumps integrity after downloading from the chip?
        I ask this to make sure that I don't get a corrupted dump.
        Thank you very much!
        09-11-2025, 10:24 AM
