Hi guys
Working on a Vizio VP-322 set with no picture.
Went thru the power supply board found a couple of bad caps (dome shaped)
Tested the rest with a ESR meter ended up replacing 9 caps total.
Set has an amber light when pluged in , turns white and a relay click when power button is pressed,but no picture
After searching around found some talk of the main board being bad
F!,F2 and some regs AMC117 .The small fuses test good.
Not sure how to test the AMC1117 or if the problem is in the main board.
Any help??
Any help??
