insignia NS-32LCD
  • mvtr2002
    • Sep 2011
    insignia NS-32LCD
    Have a insignia NS-32LCD in the shop starts fine but loses back light after 15-30 minutes. Looking at the 24 volt supply it starts out low under 23 volts as the set warms up the voltage drops to about 20 volts.The back light will come and go with no set pattern .the audio stays.
    To me seems like some capacitor problem,I have substituted 3 1000uf but same problem. diconected 24 v line voltage stays low.Turn tv off back on you get the 22v and can see a stead drop.I know(think) it is pwr supply problem but cant pin point it.It is also heat related be cause with back on problem appears,without runs ok except the fact the 24v line low .cover power supply problem starts.uncovered tv runs but that 24v bugs me.
    I appreciate any ideas/feedback thanx
    Re: insignia NS-32LCD
    What capacitors (brand, series) did you use to replace the ones on the inverter bus?
    • billansor
      • 85
      Several things to consider and to look for.
      1) The supply voltage (24) volts may be okay but it is being dragged down. Check to see if you have an abnormally hot inverter transformer. If one of them are heating more so than the others....You may want to check around that transformer and see if there is burning going on. Replacing that transformer may solve the issue. Also check caps on the inverter board too.
      2) You also may have one of the 'tubes' going bad which will also drag down your supply voltages, other members on here can verify if that is a potential possibility.
      3) Do you have a schematic? If so, can you post pictures of the power supply section?
        03-31-2024, 02:12 PM
        07-01-2024, 06:34 AM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • shamsudeen
        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
        by shamsudeen
        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
        i know that in linear power supply the noise will be very low comparing to SMPS supply....
        07-19-2025, 07:14 AM
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
