LT26MC1A with a 715T2907-2 psu
  • hifiguy
    Geoff Scott
    • Jun 2011
    • 12
    Any help would be appreciated on a BUsh LT26MC1A with a 715T2907-2 psu.
    The set responds to remote or manual switch on IE The standby light switches from red to blue and that's it, no backlight no sound. I have to switch off at mains to get back to standby.
    Upon inspection I found the 12v reg IC had failed. After extensive searching I obtained and fitted a new one which has got the 12v back up but the set behaves the same. I'm thinking eeprom corruption. Any thoughts?
    Cheers
    Geoff
    Re: LT26MC1A with a 715T2907-2 psu
    On my Lexsor TV, this was caused by a dud diode in one of the switching regulators on the main board. Test all diodes on the switching supply for a short or open circuit using a multimeter.
    • hifiguy
      Geoff Scott
      • Jun 2011
      • 12
      I need to get this one back on the bench. I'm pretty sure I checked all diodes but it's worth another look.
      Thanks Tom
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        Hi i have just been given this set its dead no standby light it has 336 v dc on mains cap zero volts on any of the secondary rails where do i start fault finding i have linked the psu schematic thanks
        Guys which pins do i need to join with 1k resistor too bench test the psu.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          R_J do you have any ideas thanks
            Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
            This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
            I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
            I am comparing them to a brand new one that I installed
            The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
            I going to let it run for several days before I remount back on the wall next to the...
            09-05-2024, 06:48 PM
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • Scoff
            LG55UB850V no picture or audio - flashing LED's help please?
            by Scoff
            Hi, I'm looking for some help with attempting to troubleshoot and hopefully repair my trusty LG55" TV.
            I'm reasonably comfortable working with electronics, but far from expert level! I have more experience with auto-electrics than anything.
            We recently had a power cut while the TV was on, and since then, when the TV is switched on at the wall, the red standby light comes on like normal. Then. when you press the power button on the remote or the TV to switch it on from standby, the standby light flashes 3 times and then goes out. There is no audio or video at...
            01-26-2022, 06:13 AM
          • hemant_2222
            Yamaha RX-V373 no voltage on the standby switch
            by hemant_2222
            Could someone please advise on this. I have this Yamaha taken from a friend for repair, especially since it had a USB for my interest. But it is not working at all.
            Here is what has been done so far. Checking the standby switch did not show 3.3 volts on one of its pins, the other was ground. it is showing as 0.60 volts. I have changed the switch as it had some resistance even when normally open. After changing the switch, I next saw that PIN 91 is not showing 3.3 volts.
            The processor clock pin show 2.8 on pin 18 (XOUT) and 0.80 on pin...
            11-29-2022, 11:33 PM
          • Natob82
            Micro Momentary Push Switch?
            by Natob82
            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
            12-21-2022, 05:22 AM
