VIZIO VO42L FHDTV10A Issues
    To start with I am new and thanks for your patience. I have VIZIO VO42L FHDTV10A that started not showing any picture, no backlight and no sound.
    When I have it plugged in I get an amber power light. When I press the power button the power light switches to white and nothing else happens.
    Please let me know what my first steps should be for troubleshooting this issue. I can get pictures on here in the next day or two but I do not have any right at this moment.
    THANKS MUCH!
    Jim
    Re: VIZIO VO42L FHDTV10A Issues
    THANKS MUCH!
    Jim
    Can you turn the TV off with the remote? Is there a U33 on the main board? Have you checked the voltages out of the power supply?
    PlainBill
      I just checked and the TV will turn on and off with the remote. I am going to look for a U33 and check voltages.
      Thanks,
      Jim
        Excuse me, have you fixed your problem?
        If yes, could you tell me the istory? cause I have the same problem but mine the sound is ok, it just has not back light.
        thanks in advance.
          thanks in advance.
          It's not the same problem then, sounds similar to 2 seconds to black.
          To verify, with tv powered on and a source connected hold a flashlight to the screen - can you see an image? If so, read below.
          PlainBill wrote a very good troubleshooting guide for 2 seconds to black, it has been re-written several times to scroll to the last version near the bottom.
          https://www.badcaps.net/forum/showthread.php?t=10419
          Good luck with your repair, if you need further help then start a new thread, it doesn't cost anything and is better for search purposes.
            Excuse me. I've done enough here in my own right that I don't need to borrow the glory of others. retiredcaps wrote (and rewrote, and rewrote) that excellent troubleshooting guide.
            PlainBill
              Apologies PlainBill - don't ask me how I got the both of you mixed up.
              I second your comment on that being an excellent guide.
                It's common - great works are often attributed to the wrong author. Last week I found a list of outstanding Science Fiction works by various authors. Under the section for Arthur C. Clarke was 'Nightfall' - written by Isaac Asimov.
                PlainBill
