VIZIO VO42L FHDTV10A Issues
  • jtandrew
    • Aug 2011
    To start with I am new and thanks for your patience. I have VIZIO VO42L FHDTV10A that started not showing any picture, no backlight and no sound.
    When I have it plugged in I get an amber power light. When I press the power button the power light switches to white and nothing else happens.
    Please let me know what my first steps should be for troubleshooting this issue. I can get pictures on here in the next day or two but I do not have any right at this moment.
    THANKS MUCH!
    Jim
  • PlainBill
    • Feb 2009
    • 7034
    Re: VIZIO VO42L FHDTV10A Issues
    THANKS MUCH!
    Jim
    Can you turn the TV off with the remote? Is there a U33 on the main board? Have you checked the voltages out of the power supply?
    PlainBill
    • jtandrew
      • Aug 2011
      I just checked and the TV will turn on and off with the remote. I am going to look for a U33 and check voltages.
      Thanks,
      Jim
      • mrquint
        • Jan 2012
        Excuse me, have you fixed your problem?
        If yes, could you tell me the istory? cause I have the same problem but mine the sound is ok, it just has not back light.
        thanks in advance.
        • bbjunkie
          • Dec 2011
          • 301
          thanks in advance.
          It's not the same problem then, sounds similar to 2 seconds to black.
          To verify, with tv powered on and a source connected hold a flashlight to the screen - can you see an image? If so, read below.
          PlainBill wrote a very good troubleshooting guide for 2 seconds to black, it has been re-written several times to scroll to the last version near the bottom.
          https://www.badcaps.net/forum/showthread.php?t=10419
          Good luck with your repair, if you need further help then start a new thread, it doesn't cost anything and is better for search purposes.
          • PlainBill
            • Feb 2009
            • 7034
            Excuse me. I've done enough here in my own right that I don't need to borrow the glory of others. retiredcaps wrote (and rewrote, and rewrote) that excellent troubleshooting guide.
            PlainBill
            • bbjunkie
              • Dec 2011
              • 301
              Apologies PlainBill - don't ask me how I got the both of you mixed up.
              I second your comment on that being an excellent guide.
              • PlainBill
                • Feb 2009
                • 7034
                It's common - great works are often attributed to the wrong author. Last week I found a list of outstanding Science Fiction works by various authors. Under the section for Arthur C. Clarke was 'Nightfall' - written by Isaac Asimov.
                PlainBill
                • ChillingCicada
                  Vizio VO42L Issues: Need Guidance
                  by ChillingCicada
                  We've had our Vizio VO42L since before 2010, and it's worked flawlessly this entire time. However, just recently it started emitting a high-pitched buzzing/humming sound. I followed the basic troubleshooting tips of just unplugging it for a moment, and even holding down the power button while doing so, all to no avail.
                  Furthermore, after I attempted these basic steps and powered the TV back on it would always begin visually flickering while the sound stuttered. After a few moments of being turned on this would go away, but it still periodically comes back.
                  I also...
                  06-09-2021, 05:47 PM
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • Daveleone
                  Vizio VO42L, white logo, no backlight, no picture
                  by Daveleone
                  Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
                  From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
                  I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
                  Main board:
                  Continuity across...
                  02-20-2021, 04:52 PM
