Sony KE-32TS2 Plasma with Sparkles
  • crtfool
    • Jun 2010
    • 82
    Does anyone have a procedure for fixing a problem with Sparkles on this model TV? I replaced a blown power supply on this set last year. The only adjustment on the power supply is a multi-position switch that was set and glued in place from the factory - it was set to the same position as the defective power supply.
    Thanks in advance for any help that you can provide.
    Re: Sony KE-32TS2 Plasma with Sparkles
    I had good luck in replacing the Vs capacitors (the big can electrolytics.) In mine they were bulged. Sparkles are still there, but much less, maybe only three or four on the entire screen every frame, which might be due to the panel aging or due to some other caps, but it's far better than it was.
    The caps in mine were Samyoung KMH 560uF 250V and were replaced with Chemi-Con KMH 560uF 250V.
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • alltvrepairs
      Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
      by alltvrepairs
      I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
      I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
      Any one met this problem in the past?...
      10-08-2025, 07:34 AM
    • Lintesir
      Panasonic P42S30 Plasma - Pink sparkles
      by Lintesir
      My parents' Panasonic P42S30 died recently, and they asked me to have a look at it. I was able to identify the SN-board as the culprit, as it was shorted. After removing Q401, Q402, Q421 and Q422 the short was gone, so I replaced these components and that got the TV working again. However, when testing the tv a bit, I noticed quite bad pinkish sparkles on some colors. For instance the greyish bar on this forum seems to trigger it quite badly. I made a fullscreen test picture with only that color, with the below result.
      There is about a 5cm high region at the top without any sparkles,...
      07-26-2024, 03:16 AM
    • lp20th
      Samsung Plasma TV Power Supply Issue
      by lp20th
      I have a vintage 2008 Samsung 50” Plasma TV, Model code PN50A550S1FXZA with a power supply part number BN44-00222A. I repaired the power supply board several years ago finding a couple of cold solder joints on the back side of the board and it's worked great up until now. Recently a fried sound occurred with the smell of burnt electronics and the TV shut down. Trying to turn it back on yielded the typical relay clicking with no TV boot up. Upon investigation, removing feeds to the other boards within the TV it was found that disconnecting the logic board from the power supply allowed the...
      11-28-2023, 10:28 AM
