Sony KDL-46S504 - Replaced Power Supply, No Picture
  • gce
    • Sep 2011
    • 8
    So, a couple weeks ago I picked up a Sony KDL-46S504 that was the victim of a power surge. According to the previous owners, the screen flashed white during a lightning storm and then they were unable to turn the TV back on.
    I'm new to electronics repair in general but I did a little research and figured out that replacing the power supply might be worth a shot. Well, now I have the new power supply installed. When I press the "power" button, I hear a click from the power supply and the front green led indicator turns on. However, that's it. I get no picture and none of the other buttons on the TV do anything.
    So, Badcaps, what do you suggest that I do next? Should I keep on keepin' on or am I just throwing good money after bad?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sony KDL-46S504 - Replaced Power Supply, No Picture
    Well, it's your money. The main board is available on eBay for under $70 from several sellers.
    PlainBill
    • gce
      • Sep 2011
      • 8
      PlainBill
      Is the Main Board the next logical step in board to replace? Is there any testing that I should do first?
        What was the problem before the power supply was replaced?
        • gce
          • Sep 2011
          • 8
          No power at all. No response to the "power" button and no green led indicator. This happened following a power surge.
          • PlainBill
            • Feb 2009
            • 7034
            Well, you can hook up a signal source (DVD player, game console, etc) and see if you can step through the inputs until you hear the audio signal. You can check the LDO regulators on the main board. The Service Manual might be available from Elektrotanya, that might provide other insights.
            Frankly, repairing anything that has taken a power surge is a crapshoot. After replacing the main board you might have to repair or replace the inverter, or find the tcon is bad.
            One thing that prevents this from becoming a totally bottomless money pit is that you should be able to sell any boards you buy at a reasonable fraction of what you paid for it.
            PlainBill
            • gce
              • Sep 2011
              • 8
              One more thing, I also noticed a slight buzzing coming from both the speakers and the top-center board on the tv (I'm not sure which board this is, it still has a metal panel covering it).
              • gce
                • Sep 2011
                • 8
                New Main Board ordered. I'll update the thread once I install it.
                • PlainBill
                  • Feb 2009
                  • 7034
                  That's the tcon.
                  PlainBill
                  • Village Electronics
                    OldPro
                    • 118
                    Posted in error
                      OldPro
                      • 118
                      posted in error
                      • gce
                        • Sep 2011
                        • 8
                        I also just looked at the back of the main board and noticed that there was some light browning in a few spots. Is this normal at all or evidence of scorching? I have to run to work but I'll post pictures later.
                          Brown marks are just signs that parts have got hot around that area. If well designed, electronic components can get hot without issue. But it is something to look out for.
                          • rmoody
                            Learning Member
                            • Jul 2011
                            • 262
                            you say no picture? What about the backlights? are they on?
                            • gce
                              • Sep 2011
                              • 8
                              nope, no backlights that i can see.
                              • westom
                                • Jul 2010
                                • 40
                                Appreciate how a surge does damage. A surge does not enter on AC mains, destroy a power supply, and stop. A surge must first have the same current flowing everywhere, simultaneously, in a path from the surge source (ie cloud) to earth. If current entered on AC mains, then some other path must be the outgoing to earth.
                                A typical path is outgoing via the cable TV coax. Because all cable TV wires are required to be earthed before entering the building. Therefore the front end (signal) circuits could be damaged. Or it could find earth via an external speaker. Arc from the speaker wire to a nearby air duct.
                                To better understand damage means locating both an incoming and outgoing electric current path. Damage will be in one or some parts in that path.
                                • gce
                                  • Sep 2011
                                  • 8
                                  "new" main board fixed it! to make it even better, the ebayer that i bought the board from made a shipping error. he ended up rectifying it and just giving the board to me for free. so i ended up getting a 46" tv for about $60 in parts! thanks to everyone for their advice.
                                    by sam_sam_sam
                                    03-31-2024, 02:12 PM
                                  • noisykid
                                    Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                                    by noisykid
                                    5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                                    12-30-2024, 07:15 PM
                                  • iglitare
                                    by iglitare
                                    09-04-2025, 07:13 AM
                                  • Goldenmonkey
                                    Samsung pn59d530a3f no picture after power supply replacement
                                    by Goldenmonkey
                                    My samsung plasma pn59d530a3f recently had a loud pop and stopped working. after opening it up, I found a blown resistor and capacitor on the power supply board. The circuit board was damaged where the resistor connects so I opted to buy a replacement board.
                                    after installing the replacement power supply, the tv powers up but has no picture. The electronics store I bought the power supply from said the next likely culprit could be the Y Main board.
                                    Is there a way to test the Y Main board before just buying a replacement? Or if there are other areas I should check?
                                    04-07-2023, 09:39 AM
