Sharp Aquos LC-46XD1E no power-up
  • marco1000
    • Mar 2015
    • 6
    • Rwanda
    Re: Sharp Aquos LC-46XD1E no power-up
    Originally posted by Khron666
    I've already checked elektrotanya, and that 6MB file is strictly the few pages of schematics from the service manual, all with the exception of the (cursed) inverter boards.
    There *IS* a return line from the inverter to the main board. It's on pin 5 of the 9-pin "LB" connector. In the block-diagram for the inverter controller, you can see that it has a "FAIL" pin, that's pulled up through a resistor. I measured that LB pin 5 today, and it sits around 1.35v at stand-by, and my multimeter caught a maximum of 2.8v before the relay clicked off and it entered that two-red-flash protection mode.
    The inverter is made up of four boards. Board 1 (top left, seen from the back of the tv) has two transformers and six lamp connectors, board 2 (lower left) has three trafos and six lamp connectors, and also contains the inverter controller. Board 3 (top right)similar to board 1, but with three trafos and six lamp connectors, and board 4 (lower right) is nearly identical to board 2 (as in, it has two pairs of switching FETs, but it gets the signals from board 2).
    I'm attaching a "stitched-together" simplified schematic of the inverter boards 1-2, as well as a couple of shots of the actual thing, including two shots of the solder side of board 2 (with the controller).
    Hello everybody am trying to fix this sharp shown above by Khron666 it have the problem of motherboard of PSC10189dm PKG1 which does not release the current to the screen and the lights does not light up. Am not able to upload the picture because am new on this forum but if somebody know something plz reply thank you.
    • Khron
      • Sep 2006
      • 1350
      • Finland
      https://www.badcaps.net/forum/showpo...0&postcount=19
      In other words, check the voltages at the outputs of all the regulators that you can, as a first step.
      Khron's Cave - Electronics - Audio - Teardowns - Mods - Repairs - Projects - Music - Rants - Shenanigans
      • FindTheShort
        • Jul 2016
        • United Kingdom
        I got a cheap SHARP LC46XD1E from ebay. Refurb it and turned it on, all worked, very happy. Then as usual, I tried to measure inverter output with a DMM, 5mm long plasma jumped out of the secondary inverter coil to the meter probe, then everything went kaput! Maybe some lights blinked, but I kept pressing the power button and didn't see it. Relay clicked for 1 second and off again.
        P-CH MOSFET Q7403 on the #2 inverter board (out of 4), was shorted out.
        1. Replaced the shorted MOSFET, still not working!
        2. Downloaded the service manual, some voltages on LA, PL, PA, PB, PC turned on at STAND BY, some were simulated to turn on. Therefore, I assumed all regulators on the power board were ok.
        3. Replaced all 4 inverter boards, still not working!
        4. Replaced the power board, just in case, still not working!
        5. During the relay clicked for 1 secend, on the power board, PB pin 6 (power error POWER_ERR) line has 3.3V. It should have 0V due to Q739.
        6. At the same time, PB pin 8 (TCON board 12V trigger LCD_POW) has 0V. This signal directly comes from the CPU/FPGA. So, I suspected the main board was faulty.
        7. While reading how to perform a hard reset procedure, I came across the Adjustment Process Mode. The precedures to get in/out of it are as follow:
        1. Press the "POWER" key on the set of running TV set to force off the power.
        2. While holding down the "VOL(-)" and "MENU" keys on the set at once, Press the "POWER" key on the set
        to turn on the power. The letter "K" appears on the screen.
        3. Next, hold down the "VOL(-)" and "P(V)" keys on the set at once.
        Multiple lines of orange characters appearing on the screen indicate that the set is now in the
        adjustment Process mode. If you fail to enter the adjustment process mode (the display is the same as
        normal startup), retry the procedure.
        4. To exit the adjustment process mode after the adjustment is done, unplug the AC power cord to force off
        the power. (When the power is turned off with the remote controller, once unplug the AC power cord and
        plug it in again. In this case, wait 10 seconds or so before plugging.)
        5. To remove "K" mode, just repeat step1 and 2. This time the letter "K" disappears from screen.
        In the Adjustment Process Mode, I saw 5 lamp errors under INFO (1b LAMP ERROR some hours and mins here), went to ETC menu, and reset the lamp error count (L ERR RESET) from 5 to 0.
        TV turns on with no more 1 second relay click. It's fixed!!! In this case, it should have only cost me a P-CH MOSFET Q7403 and F7401 on the #2 inverter board, but I didn't know. So, I ended up buying all 4 inverter boads + power board. Lucky didn't buy the main board! Hope this helps you.
        • JFarm
          Sharp Aquos LC-46E77UN inverter testing
          by JFarm
          I picked this TV out of a trash pile. When I plug it in I can hear the relay on the power supply “click” almost immediately, and then 7 seconds later there is another “click” and the power/OPC LEDs start to flash: two pulses on the power LED, one on the OPC LED. I didn't notice any sign of life from the backlight, but more on that below.....
          The service manual () says this is a “DET_10V error: UR10V or A9V is not applied”, but after checking several voltages I believe the power unit is tripping off due to an overload as soon as the backlight tries to come on; this kills...
          03-21-2021, 11:10 AM
        • scubacamper
          Sharp Aquos LC-70C6400U Half Screen Dark
          by scubacamper
          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
          05-03-2025, 12:19 PM
        • sefoster
          Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
          by sefoster
          I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
          11-20-2022, 09:29 AM
        • jonah1024
          Sharp Aquos LC-40UG7252E LCD TV burn in?
          by jonah1024
          Hello!
          I'm a few days old into this TV screens repair universe so please bear with me.
          Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
          - I did the classic unplug and hold power button to discharge the caps but it didn't help.
          - I did a factory reset as well...
          07-16-2024, 04:23 AM
        • klassic
          Sharp Aquos LC-60LE635E three blinks
          by klassic
          Hi community,
          I will describe my problem with a TV in those short following terms to be the most precise :
          What i have :
          power board DPS-162KP-1
          main logic board QPWBXF733WJN2
          symptoms :
          white led light logo at startup,
          after 2 minutes, blinking 3 times a row, repeating
          no backlight (and apparently no picture, checked panel with flashlight)
          no startup sound
          powerboard investigations :
          1-2 PNL : 0v
          3-4 GND
          5-6-7-8 UR : 13.15v
          9-10-11-12...
          10-24-2023, 01:39 PM
