I have a Sharp Aquos that has a blinking power light only. Based on the service manual it says it has a bad panel? Can I take this at face value or could it be another issue? I've checked voltages to the inverter and main board. They check good to what is on the power board. I've unplugged the tcon board to see if I can just get the backlights, but nothing.
Sharp Aquos LC-42D65U No Backlight/Sound
Re: Sharp Aquos LC-42D65U No Backlight/Sound
Update - after confirming voltages, decided to swap out inverter. The inverter looks like some children soldered it together. I could confirm 24v going to the transformers but it seems like the startup would fail when trying to start the backlights. New inverter works, backlights working. -
This brings up a point I seldom think about. On many TVs the inverter is considered part of the LCD panel.Update - after confirming voltages, decided to swap out inverter. The inverter looks like some children soldered it together. I could confirm 24v going to the transformers but it seems like the startup would fail when trying to start the backlights. New inverter works, backlights working.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Good to know that the manufacture considers the Inverter Board part of the LCD panel. I have noticed that when they ship out new screens it comes with parts. Sometimes they come with all the parts except for the main board and Power Supply.
I am about to work on this LC-42D65U, I will look first at the Inverter Board.Comment
If you look at the spec sheet of the LCD panel, you will see spec sheet of the T-CON and the Inverter board, those two boards are usually shipped with the panel to the TV manufacturer.Good to know that the manufacture considers the Inverter Board part of the LCD panel. I have noticed that when they ship out new screens it comes with parts. Sometimes they come with all the parts except for the main board and Power Supply.
The newer panel with LED backlights usually does not come with LED drivers.Attached FilesNever stop learning
I have a Brand New 60" Samsung Plasma Screen right here, still wrapped in plastic. No TV to put it in. It has all the boards on it except the power and main. And there is no buttons. All I need is a frame.Comment
by IerwinHello everyone,
Anyway I still fully expect that there has been something seriously damaged... -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by QuestcomHi All,
I have recently purchased a faulty Sharp Aquos 40aj6ke which turns on and has backlight but has no sound or video, the person I brought it from told me he had changed the main board and the same fault was there.
I have tested voltages on main board and they seems ok, the backlight is at 75v, I believe this tv has 3 x 8 strips of leds which 75v would work out to around 3v per led
I think the issue is on the board that attaches to the lcd, doing a bit of digging watching videos etc, there is a lot of mention of vgl and vgh being around -8 and... -
by Superbee_dadHello Sharp TV experts
Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
> I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
> There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...01-24-2025, 11:51 PM -
by triplefourTCL 75S421
PSU BOARD: 40-L402H8-PWD1CG
it shows not even a flash of backlight when powering up.
but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
with mb connected, PSON... - Loading...
