Olevia 532H-B13 - Picture Freezes
  • stevekasian
    Old N00b
    • 182
    • USA - West Side!
    I have an Olevia 532H-B13 LCD TV. Everything works perfectly except the picture freezes (with absolutely no distortion, just a perfect freeze frame of whatever was on the screen) when it warms up (from cold, it takes about 2 minutes or so).
    Does anyone know which board would most probably be responsible for this?
    (There are no bulging caps visible... yet.)
    Thanks!
    SK
    Re: Olevia 532H-B13 - Picture Freezes
    One possible cause is a loose LVDS cable or connector going to the LCD panel, though that usually does introduce some picture glitches.
    When frozen, can you turn on/off the set using the buttons or remote control? Does sound continue?
    • stevekasian
      Old N00b
      • 182
      • USA - West Side!
      I'll have to double check and make sure - I've torn the thing down at this point.
      SK
        http://www.youtube.com/watch?v=bnfymg6ip6A
        That's what a loose LVDS cable can cause.
        Thermal expansion *could* be causing it to disconnect after a few minutes of operation. However, as in the video, when the cable goes loose it's *usually* followed by distortion, like horizontal lines or a change of colour. If you're lucky, just pressing the cable down will fix it for a year or two; maybe there's a more permanent fix.
        • cadiman
          • Mar 2010
          • 397
          I would go after the mainboard / video board where the signal starts out.
          • stevekasian
            Old N00b
            • 182
            • USA - West Side!
            Yeah, it's nothing at all like in that video you linked to.
            Now I'm noticing that it sometimes freezes on a blue screen when turning it off and on again once it's warm, and sometimes a black screen. But most often, the Olevia logo pops up with a white background first and it freezes on that.
            I'm also noticing that sometimes there is weird distortion (almost like ASCII characters) along the very bottom of the screen (up to about 1/4" from the bottom in a horizontal line) just before it freezes. The best way I can describe the distortion is sort of like if you take an old Commodore 64 home computer and POKE53272,xxx (any value between 1 and 255 other than the default value) and watch what happens to the screen. Weird characters randomly populate the screen, some jumping around and randomly paging through CHR$ values at varying speeds.
            Don't know if this helps or not.
            SK
            • JJAAMM
              by JJAAMM
              Problem
              07-06-2023, 06:01 AM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • CyberPhoenix
              Issue with picture quality of Sony bravia TV
              by CyberPhoenix
              Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
              01-22-2024, 02:08 AM
            • Rauni
              Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
              by Rauni
              Hello, this is my first post on this forum, and my first attempted to repair a TV.
              My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
              Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
              Read also that we should test what happens if we...
              10-01-2023, 12:06 AM
