Replaced a tcon board in a sony bravia today. I now have sound and only a backlit display. I am going to test the white fuse on the new tcon board tommorrow as I saw it was suggested on another post from last year. I cannot replace the tcon with the old tcon since it appears a gorrilla removed it out of the tv and broke the connectors on the top of the board. Is there any possibility that it ripped the internals of the ribbon cables on the top of the board? Are they replaceable if so?
Sony bravia 40v4100 problem after installing tcon
Tags: None
Re: Sony bravia 40v4100 problem after installing tcon
Yes, it is possible. No, they are not replaceable.
One word of caution. Gorillas are very sensitive, and will take offense when they find out you used their name to refer to a clumsy human. Be very careful the next time you visit the zoo. Avoid the primates - you won't like what they throw at you.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
by JUCaESAlHola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television. -
by swrb898What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
Problem:
Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
My troubleshooting got me this far:
With the left-hand TCON to bottom-board ribbon cable... -
by iglitareHi,
Or is it always a bad/shorted... -
by PopsCapsI have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
I do not hear any sound and I cannot see any backlight.
I have tried disconnecting every cable on each board one at a time to see if anything changes.
The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
My friend ordered another used power supply board but it is also doing the red indicator flash 3 times... -
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... - Loading...
