Sony bravia 40v4100 problem after installing tcon
  • greysquirrel00
    • Aug 2011
    Replaced a tcon board in a sony bravia today. I now have sound and only a backlit display. I am going to test the white fuse on the new tcon board tommorrow as I saw it was suggested on another post from last year. I cannot replace the tcon with the old tcon since it appears a gorrilla removed it out of the tv and broke the connectors on the top of the board. Is there any possibility that it ripped the internals of the ribbon cables on the top of the board? Are they replaceable if so?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sony bravia 40v4100 problem after installing tcon
    Yes, it is possible. No, they are not replaceable.
    One word of caution. Gorillas are very sensitive, and will take offense when they find out you used their name to refer to a clumsy human. Be very careful the next time you visit the zoo. Avoid the primates - you won't like what they throw at you.
    PlainBill
    • swrb898
      Sony KD-70X690E Bravia; Bad TCON? Bad panel?
      by swrb898
      What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
      Problem:
      Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
      My troubleshooting got me this far:
      With the left-hand TCON to bottom-board ribbon cable...
      12-28-2021, 08:12 PM
    • iglitare
      Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
      by iglitare
      i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
      Backlight seems to work, Sound (Setup menu after reset) works.
      If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
      Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
      With my small knowledge i would think at least the cables are good.
      Can this happen because of a bad tcon board?
      Or is it always a bad/shorted...
      09-04-2025, 07:13 AM
    • PopsCaps
      Sony Bravia KDL-40V2500 that will not power on
      by PopsCaps
      I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
      I do not hear any sound and I cannot see any backlight.
      I have tried disconnecting every cable on each board one at a time to see if anything changes.
      The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
      My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
      03-25-2025, 11:23 AM
    • kca
      by kca
      Hello all ~
      08-31-2025, 06:38 AM
    • thelankanguy
      Sony KD-55X9000F TCON Issue
      by thelankanguy
      The TV shows a black screen with no image.
      TCON ribbon connectors were disconnected individually for image and there was no half image even.
      Later both ribbons were disconnected and TCON voltages were tested.
      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
      There is also a short to ground in this circled inductor.
      Is this a TCON issue or something else ?...
      12-13-2024, 12:27 AM
