Another TV issue
  • Tom41
    • Oct 2005
    • 336
    • England
    Another TV issue
    As I mentioned in my previous thread, my TV has recently bitten the dust and won't power on (it only makes a loud buzzing noise). I have a spare TV which I'm using right now, but it has a couple of things wrong.
    First, and most annoying, is that it makes a loud high-pitched noise when on. I don't mean the quiet whistle that most CRT TVs make when switched on, this sounds similar but is MUCH louder. Sometimes, if I hit the top of the TV, the noise will stop - only to come back a few minutes later.
    The second thing is, the colors are much too bright - I have to turn the color control down to make them look right. If I touch the buttons on the front of the TV, the color level changes and occasionally goes back to the 'proper' level. I assume there might be a loose wire or dry solder joint on the board - what do you think?
    It's a Sony Trinitron set, 14-inch screen, PAL (60hz compatible) with mono sound. A friend of mine (who is good with electronics) says that I should try reseating the suction cup on the tube to try and fix the whistling problem. But to do that, I'd probably need to discharge the tube. I read somewhere about wiring a screwdriver to ground and pushing it under the suction cup, but that sounds dangerous! How DO you go about discharging the tube and reseating the suction cup anyway?
    You know there's something wrong when you open your PC and it has vented Rubycons...
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Another TV issue
    try sticking a toothpick between the core and body of the flyback.
    the core sometimes gets loose and sings to you.
    dont need to mess with the hv lead.if it was loose/dirty it would hiss and arc loudly.
    • chipper
      • Aug 2008
      • 95
      Loud whistling from CRT's comes from where the suction cup (red wire) lead begins usually. Then it is transferred to the suction cup and clip on the tube opening. Sometimes , all that has happened is that someone has turned up the flyback settings that are the 2or3 (black plastic cross shaped or star screws) that are on the side of the unit where the red wire leads to at the PCB. Alot of tv's have built in holes in the plastic cover that allow the RGB or RED,GREEN,BLUE setting screws to be altered according to preference , and a whistle may result . Each setting screw should be changed with a plastic screw driver (metal is OK) , until the whistling is gone or lowered. With older tv's once this happens there is usually no cure , but , if they were maladjusted by a user , they can be corrected through viewing the colors vs. the whistling sound.
      You should turn the brightness up full (visable) at the tv before setting the flyback , then turn it down accordingly after you have achieved the best (less whistling) settings. This should get rid of the problem. If it doesn't the flyback transformer is worn out or almost ready to stop working (reached it's life's end). [too many hours on it]
      • rounin
        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
        by rounin
        I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
        🛠 Original Issue
        The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
        04-19-2025, 01:18 AM
      • ugamazing
        Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
        by ugamazing
        I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
        We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
        12-17-2024, 07:05 PM
      • ahmarzo
        Acer laptop battery draining issue
        by ahmarzo
        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
        08-02-2025, 06:39 AM
      • elmark
        HP 15-cw1002ua strange keyboard issue
        by elmark
        HP Pavilion 15-CW1002UA
        S/N 5CD0251CBC
        P/N 7KE54EA
        Hello guys!
        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
        It powers on OK and has no other issues except the following:
        • CAPS LOCK does not work at all
        • Fn button toggles Flight Mode
        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
        • (with SHIFT pressed: 't%' and 'y^' respectively)
        I initially thought it was a keyboard malfunction (internal short, etc.),
        but when I press and hold...
        06-27-2025, 01:10 AM
      • DCJack
        B&K 707 tube tester. I need help.
        by DCJack
        Hi everyone!
        I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
        Initially I noticed that I was not getting the red on-light to turn on, but it...
        03-05-2024, 05:05 PM
