Sansui SV 1402 IC - TV set
  • burntfingers
    • Jan 2011
    • 148
    Hi, guys.
    I'm looking for the service diagram.
    Looked around other sites, but nothing!
    Just need to see voltage at horizontal driver [I only get 4v at collector... I'm intrigued; transistor is OK].
  • burntfingers
    • Jan 2011
    • 148
    Re: Sansui SV 1402 IC - TV set
    Does this mean I have no luck this time...
    • Coert van Dorsten
      Sansui Integrated Amplifier replacement volume control troubles
      by Coert van Dorsten
      Hi all you clever electronmic gooroos!
      I was wondering if you could help me with the below issues Im having on a Sansui Integrated amplifier. I bought this unit as a project to repair as Im playing around with basic electromics.The unit has a faulty volume control pot. The service maual refers to a 150K Logarithmic pot (A) tapered stereo. Im struggling to find this value. Seem to be a jump from 100K to 250K. Im now trying a 250K pot. It works but the problem is that as the volume is turned up from starting at Min the Left channel will come on first just slightly before the Right...
      10-15-2025, 02:54 PM
    • Hornnumb2
      Sansui sled4019 dim picture
      by Hornnumb2
      I have a sansui that just started having a dim picture, adjusting backlight settings up or down have no effect on display. I went ahead and ordered some backlight strips for it but find it weird that changing the setting has no effect. Could it be power related. Where should I start? Thanks Michael ...
      08-31-2025, 10:37 PM
    • Hornnumb2
      by Hornnumb2
    • Neddsme
      SANSUI SLEDSC-32HD TV not booting, No stand-by led
      by Neddsme
      I have a 32 inch Sansui android TV that stopped booting. i checked the motherboard for any power failures but it seemed OK to the best of my knowledge. The TV does not have a dedicated power supply board so i could not do any isolation but here is a list of all the things i think were relevant to test.
      if i missed anything you let me know;
      DDR (1.5V) = 1.484V
      VDDC = 1.000V
      VDDC_CPU = 1.151V
      VDD1V2_DM = 0.000V
      3V3_STB = 3.315V
      3V3_M = 3.307V
      1.8V_M = 1.803V
      ALL KEYS = 3.310V
      5V_STB = 5.142V
      5V ...
      11-02-2023, 01:33 PM
    • stomanata
      Problem with Samsung HT-DB120
      by stomanata
      this system has mainboard HT-DB120/THA25.
      Display working and also i can switch modes, but there
      is no audio.
      I noticed that resistor R100 is heating up.
      I found wiring in attach, but there is diferences.
      1. In this wiring 1st pin of resistor is attached to diode bridge and
      second pin is attached to Collector of PQ5. On PCB is not the same.
      2. Resistor R100 is labaled as 10ohm, but it is 22ohm. Even colour
      code (red, red, black, gold) show 22 ohm.
      3. Emitter of PQ5 must go to PIC4 (7812), but this also is not true.
      So, it seems...
      05-01-2024, 10:35 AM
