Proline DVD player + combined surround sound system
    Got this thing cheap - it's a DVD player with built in 5.1.
    Anyway, the symptoms are it does nothing when plugged in - it's completely dead.
    If you listen carefully you can hear a clicking/ticking sound at 2-3 Hz. I scoped the rails and can see them rising, but they quickly fall, at the same rate. Power supply is trying to switch on but for some reason is failing.
    I have replaced:
    all bulging caps on the secondary side -> same problem
    one non-bulging big cap on the secondary side -> same problem
    the 22u/50V startup/Vcc cap (replaced with a general purpose 22u/35V) -> same problem
    The power switch is Fairchild KA1L0380RB. Max Vcc is 30V so 35V cap should be fine.
    All caps replaced with Panasonic FM or FR.
    Big primary filter cap has about 332V across it which is good.
    Power supply does exactly the same without load -> power supply probably at fault then.
    Only dodgy thing at the moment is that Vcc seems to ripple about around 10-18V even with the cap replaced. Measured from either end of the cap, Vcc to GND. Vcc is provided through a high value resistor. Reads yellow purple yellow gold -> 470k 5%. Measuring it in circuit (with power off) drives my meter crazy, why? It doesn't look like it is connected in parallel with anything. I will try replacing it with a 470k resistor carbon film 5%, perhaps it is just broken, maybe it is burnt out from years of use, although it doesn't look like it. May explain ripple on Vcc. A bad cap failing open, assuming 300V across the resistor, would have it dissipating 0.191W, which is within limits. But a cap failing shorted would bump it up to 0.234W, still within limits, but running near.
    At a loss at what to try next?
    How do I test the opto?
    Re: Proline DVD player + combined surround sound system
    470k removed, measured 468.8k, seems good, replaced it anyway, still broke.
    Anything else to test?
      Ah!!!
      Noticed 5V rail was completely dead.
      Tested diode - DEAD SHORT, both ways.
      The 5V is used by the feedback so if it is dead then it will not start.
      Hope this is the only problem but it's faulty either way and it wouldn't work without it.
      • PlainBill
        • Feb 2009
        • 7034
        Originally posted by tom66
        Ah!!!
        Good catch. Your analysis was faulty, however. A shorted diode on any transformer secondary will kill the operation of the power supply. In addition to the primary and secondaries, the standby (main on a single supply design) transformer has another winding (which I refer to as the tertiary winding) which provides run power for the SMPS controller. With a short (or even just excessive load) on the secondary, the tertiary winding does not generate sufficient voltage to provide power to the SMPS controller.
        The ticking sound you observed is an excellent clue. Your noticing the dead power supply rail and following it to the cause was good troubleshooting.
        PlainBill
          PlainBill
          I'm not sure a shorted diode would short out the secondary though? The diode's purpose is to block and rectify the AC from the transformer. If the diode is no longer blocking AC, I am worried that it could have toasted some other components on the main board. On the other hand, AC into a capacitor is virtually a dead short. So it might have been saved by the cap shorting it out.
          I think the winding you talk about is the bias/Vcc winding for powering the SMPS controller? See schematic - the 22ohm (R8) and diode (V7) provide power to the switcher once the startup cap (C7) is charged through the 470k (R3). The only difference between standby and bias is that the bias doesn't need to be mains isolated as the controller is purely primary side.
          There is no standby power supply - the power supply is either on or off. Oddly, there is a pin called STBY/ONOFF on the board. But it's not connected to anything?! The only on/off is through a *real* mains on/off switch at the front and the soft on-off through the remote.
          • PlainBill
            • Feb 2009
            • 7034
            I'll point out a few things. in no particular order.
            1. You provided neither a model number nor any pictures. In the future I will ignore any of your threads that fail to provide basic information.
            2. Some smaller TVs have a single power supply; in general any TV over 24" will have a dual supply.
            3. At startup the SMPS controller gets it's power from the rectified mains voltage. The tertiary winding provides run power. Calling it a bias voltage is incorrect.
            4. A typical frequency for a SMPS controller is 70 Khz. At a guess, the 5V filter cap is in the order of 1000 uF. You can figure out the impedance there, for all practical purposes it is an AC coupled dead short.
            5. What @#%@#% schematic?? That's something else you didn't provide!
            PlainBill
              Pics attached.
              But no model number on the back anywhere...!
              All I know is it is a Proline 5.1 + DVD combined unit.
              Most do. I've only seen the occasional small CRT without one. All LCDs thus far seem to have one.
              That's the 470k's job to provide the bootstrap power.
              I've heard it called bias in a TOPswitch PSU control IC, they are usually used for standby power and mains switchmode wall warts.
              I call it the Vcc winding because it directly drives Vcc of the 4-pin switcher IC.
              Xc = 1/(2pi*f*C) IIRC, comes to 2x10^-9 so seems about right for dead short... ignoring ESR of a few milliohms.
              PlainBill
              My error! Getting confused and forgot to post it. Here it is:
              Page 10 has the power supply.
              I got a schematic by googling the PSU model.
              While the schematic is similar it is not identical. Still, it was useful in debugging the PSU.
                Replaced the diode, it works! Great. Simple fixes I like.
                  Okay, it powers up. But it makes a buzzing sound on the speakers (sounds like 50/100 Hz) and won't read discs. I am thinking a ground loop. But I have attached all grounds. What other places are there to check?
                  • joste
                    • Aug 2011
                    • 42
                    Hi Tom66,
                    I would change that big primary filter cap anyway. Sometimes it can cause weird things. If you have a buzzing sound around 50Hz, this would be my lucky guess.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      I second that suggestion.
                      A working TV? How boring!
                      • lti
                        • May 2011
                        • 2548
                        What about the IC with a burnt sticker on top of it? That could be the reason why it won't read a disc.
                          Originally posted by joste
                          Hi Tom66,
                          Okay, I'll add it to my next component order and see if that makes a difference.
                          The amplifier has an odd configuration: it is powered from a separate transformer. The transformer is very large, although probably underpowered. I can't help but think a good SMPS could have powered the 60W amplifier side, and have reduced the cost... This whole player is odd, though - it's like it's made from loads of different OEM parts and through some miracle it manages to work, when it's not broken, of course.
                            I think that is the decoder and CPU. I peeled the sticker off, just looks like it is worn from heat, chip is fine. As I have an interface on the VFD I don't think it is fried. It is trying to read the disc: the laser head moves back and forwards over the disc, and the disc spins, but it eventually just says "NO DISC" on the front VFD. Opening/closing drive works fine. Oddly, most noise seems to come when it opens and closes. It can determine the difference between having a disc and no disc - without a disc it gives up in 1-2 seconds; with one, it takes about 1 minute.
                            • joste
                              • Aug 2011
                              • 42
                              So Tom66, this looks like your laser has gone half-blind (somewhat out of focus): when the disc is inserted, the unit tries to read out the data (type of the disc, sessions etc.) but the beam is not focused enough to clearly read it, so it gives up after a minute. When the disc is absent, the unit spins twice or trice and reads "no disc". This is quite normal.
                              My question: did you try plain audio CD instead of DVD? Sometimes lasers can not read one, but still manage to read other type of discs.
                              Looking forward to your answer.
                                Good news - it does play audio CDs, and with no buzzing. This is weird! So do you think I just need to clean the laser?
                                • joste
                                  • Aug 2011
                                  • 42
                                  Well, that can be your first try.
                                  If cleaning doesn't help, I'd suggest to go for much trickier operation: adjusting laser focus (if possible).
                                  But, first things first - lens cleaning (but be careful with pressure applied and no liquid!).
                                    That was easy. I rubbed the laser with a bit of tissue paper and it now reads DVDs and CDs. Easy fix ! I guess it must have had a bit of dirt on the lens.
                                    • joste
                                      • Aug 2011
                                      • 42
                                      So Tom66, would you call it "problem solved"?
                                        Yep .
                                        When a disk is first loaded into it, the audio has a slight buzzing sound... some kind of weird glitch. But once loaded and playing, the audio is crystal clear. I'm not sure if I even need to replace that 47u/400V capacitor on the input now.
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • japlytic
                                          Not all TVs can handle surround sound on a HDMI input
                                          by japlytic
                                          With a home theatre PC connected to a TV via HDMI, Windows reveals that the TV only supports stereo sound even though the TV has a HDMI ARC connection to an AV receiver which is powered on; I also had an issue that the AV receiver does not always retain the input setting for routing the HTPC video through to the TV in standby.
                                          So I connected a second HDMI cable to the HTPC and set it to duplicate the video outputs, but I had random audio dropouts when playing content with surround sound being passed to the AV receiver (dropouts did not occur when I replayed the content where it dropped...
                                          08-31-2022, 10:09 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
