Got this thing cheap - it's a DVD player with built in 5.1.
Anyway, the symptoms are it does nothing when plugged in - it's completely dead.
If you listen carefully you can hear a clicking/ticking sound at 2-3 Hz. I scoped the rails and can see them rising, but they quickly fall, at the same rate. Power supply is trying to switch on but for some reason is failing.
I have replaced:
all bulging caps on the secondary side -> same problem
one non-bulging big cap on the secondary side -> same problem
the 22u/50V startup/Vcc cap (replaced with a general purpose 22u/35V) -> same problem
The power switch is Fairchild KA1L0380RB. Max Vcc is 30V so 35V cap should be fine.
All caps replaced with Panasonic FM or FR.
Big primary filter cap has about 332V across it which is good.
Power supply does exactly the same without load -> power supply probably at fault then.
Only dodgy thing at the moment is that Vcc seems to ripple about around 10-18V even with the cap replaced. Measured from either end of the cap, Vcc to GND. Vcc is provided through a high value resistor. Reads yellow purple yellow gold -> 470k 5%. Measuring it in circuit (with power off) drives my meter crazy, why? It doesn't look like it is connected in parallel with anything. I will try replacing it with a 470k resistor carbon film 5%, perhaps it is just broken, maybe it is burnt out from years of use, although it doesn't look like it. May explain ripple on Vcc. A bad cap failing open, assuming 300V across the resistor, would have it dissipating 0.191W, which is within limits. But a cap failing shorted would bump it up to 0.234W, still within limits, but running near.
At a loss at what to try next?
How do I test the opto?
I have replaced:
