Repairing the video board on an LG 26LX1D
  • lkvee
    • Feb 2009
    • 198
    Got the TV from Freecycle. The power board had a shorted capacitor (the C126 at 47 uf and 50V). Replaced that and got power and a signal.
    Component, composite, and RGB (VGA) signals are noisy (slightly fuzzy). I couldn't even test it with my XBox 360 composite cable (Invalid Format message). HDMI looks great.
    I read about someone replacing the capacitors on the video board:
    http://s807.photobucket.com/albums/y...3DDSC01913.jpg
    OR http://tinyurl.com/3qegqfl
    I see surface-mounted caps, too. I don't have any experience with removing or replacing them. I'm grateful for this URL because I've been calling them polymer capacitors up until reading that page:
    http://capacitorlab.com/capacitor-ty...-smt/index.htm
    I'm also reading up on removing and replacing these types of capacitors here:
    http://www.co-bw.com/DIY_Replacing_SMD_capacitor.htm
    Can I get a clean-enough signal by just replacing the electrolytics and leaving the surface-mounted capacitors alone?
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Repairing the video board on an LG 26LX1D
    No idea, but you can try and find out. The surface mounted capacitors are either ceramic (if they're small and light brown with nothing printed on them), or tantalum, which are larger in both size and capacity, and have values printed on them. Tantalums are more likely to fail than ceramics.
    A working TV? How boring!
    • lti
      • May 2011
      • 2557
      That board has surface mounted electrolytic caps.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Noodneek
        Replacing all the caps on the BenQ SW2700pt's power board didn't help...
        by Noodneek
        My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
        I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
        08-30-2024, 12:52 PM
      • MacGyver's paperclip
        what to check before replacing hybrid MOSFET/controller IC on SAMSUNG TV power board
        by MacGyver's paperclip
        TLDNR; Have an old SAMSUNG TV with blown hybrid MOSFET/controller IC on power board to be replaced; replaced blown main capacitor on same power board several years ago successfully, and TV has been working fine since until this IC popped all of a sudden. Want to know what if anything to check on board to make sure before replacing and testing with new IC. Have 2 new matching ICs, DIP socket to make removal/replacement easier, a whole other known-good power board with which to compare, if necessary.
        07-01-2023, 12:12 PM
