AKAI 50" plasma tv no picture no sound
  • bikerbuddy
    • Jun 2011
    • 134
    I have an Akai 50' plasma tv with no picture and no sound , It started about a month ago when one day I try to turn the tv on, it power up with no pic and no sound, but I tried turning it on with the main power switch on the back of the set, some time it will power up with the Akai logo and blue screen for a second or two then the screen will disappear after a few second the akai logo will appear again and disappear and it will repeat it self over and over.
    I opened the back cover and check all the out put voltage , I got 5v , which is stable ,Va 60 v which is stable and Vs 190v which did look to be stable but as I keep checking the all the voltage every now and then I notice that the Vs190
    V was fluctuating from I90v down to 159v and up again , I do not see any bad or bulged caps , I disconnect the Z board and check the voltage still the same
    disconnect the Y board the power drop even lower, when I connect all the boards 5v become stable 60V become but the Va will show 190 v then after a few seconds will start to drop and rise .
    I have three light on , on the ctrl board , some time the d2 light will go off , and comes on back .
    I know the y , Z and Y sustain board are ok ,I am thinking of main board .
    Any and all help is highly appreciated
    Re: AKAI 50" plasma tv no picture no sound
    Can you post some pics of the board?
    • bikerbuddy
      • Jun 2011
      • 134
      here are a few pic for the AKAi 50" plasma
        Can you measure the voltage across the input cap?
        (I'm suspecting either the input mains cap, or the PDP HV caps.)
        • bikerbuddy
          • Jun 2011
          • 134
          Tom I will check the voltage on the caps first thing in the morning and post it.
          also I have noticed that one of the diode, #is ST02D-200 (200V 300watts)there is no resistance .
          thanks
            thanks
            No resistance? Zero ohms or open loop? Did you try diode test mode?
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • Mgiffune
              by Mgiffune
              06-09-2024, 10:28 AM
            • Ierwin
              by Ierwin
              05-13-2025, 03:31 PM
            • jchang
              Samsung UN70NU6900F no picture and no sound
              by jchang
              Hi all
              I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
              Symptom:
              No picture no sound.
              When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
              No sound at all.
              What I tried:
              1. I tried unplugging the left or right ribbon...
              01-09-2023, 06:28 PM
