Need Help Finding a El 817 B926 Photocoupler On Digikey
  • 70JUDGE
    • Jul 2010
    • 81
    I am trying to find a component called a photocoupler on digikey,but I am not having any luck.I have tried all the combinations of the letters,and numbers written on it,but I can't seem to find one.It says EL 817 B926.Any help is greatly appreciated.Thank You very much!
    Tyler
  • Dgtech
    E. Technician
    • Apr 2009
    • 1462
    • Steeler
    Re: Need Help Finding a El 817 B926 Photocoupler On Digikey
    Photocouplers are the same as Opto-isolators aren't they? If so, You might find them under that. If you can find a data sheet for the part that you have, then look up an equivalent part.
    • Toasty
      • Jul 2007
      • 4171
      Mouser has them:
      http://www.mouser.com/Search/Refine.aspx?Keyword=el817
      veritas odium parit
      • retiredcaps
        • Apr 2010
        • 9271
        findchips.com will search about 20 or so vendors for you.
        http://www.findchips.com/avail?part=EL817
        --- begin sig file ---
        --- end sig file ---
        • Toasty
          • Jul 2007
          • 4171
          Yup, but Mouser's the cheapest -
          - Future is cheaper by the piece, but $9 FedEx Ground. No Priority Mail.
          - Arrow is cheaper yet, but minimum order is $25 and S/H is $8.
          All the Intersil numbers are the WRONG device (op-amp).
          Cheers!
          Toast
          veritas odium parit
          • PlainBill
            • Feb 2009
            • 7034
            It appears the following part numbers from Digi-key are matches for the original. If the row to row lead spacing is .3" this should work or if the row to row lead spacing is .4" use this one.
            PlainBill
            • Tvbob
              tvbob
              • 204
              EBAY is the place to go first, 817 is the key in the search.
              ebay has 10 photo coupler's $5.00 free shipping
              • Dgtech
                E. Technician
                • Apr 2009
                • 1462
                • Steeler
                Wow, ten!!! Just what we all need.
                • PlainBill
                  • Feb 2009
                  • 7034
                  And coming all the way from China!
                  PlainBill
                  • Longbow
                    • Jun 2011
                    • 623
                    My question is this: are you repairing a power supply, and isolated the fault to the opto-coupler? If so, how did you determine that this part was faulty?
                    Here is some information that might be helpful. SMPS use opto-couplers in the negative feedback loop in order to maintain isolation between primary and secondary. The good news is that they are all very similar. Being in the feedback loop, the part will "self-adjust" and thus the specs are not critical. Desolder one from a spare parts board if you have doubts.
                    One side of the coupler is an LED. That can easily be tested with your multimeter. The other side is an opto-transistor. The part operates at low voltage, low current, and low frequency. The failure rate is very low.
                    Is it plugged in?
                    • quickname
                      Cyberpower 1500AVR UPS repair
                      by quickname
                      I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                      I decided to verify that the batteries were...
                      11-12-2023, 09:57 AM
                    • mrkmpn
                      Finding comparable ferrite beads on mouser/digikey?
                      by mrkmpn
                      I have an inspiron with "power rail failure" LED codes flashing, and have found a blown capacitor and ferrite bead (inductor, I guess...)
                      I've found the replacement capacitor on mouser, but am unsure how to properly search for the ferrite bead. I have the schematics and boardview, so I have found the original bead part#, but the data sheet doesn't seem to include the information I need for the filters on mouser and digikey.
                      For inductance, and a few other values it just says "Refer to standard electrical characteristics list"
                      Here's...
                      10-12-2022, 01:54 PM
                    • corrize
                      Where to buy photocoupler 4N3R or similar please ?
                      by corrize
                      Hello, I'm repairing an old mini-PC Gigabyte Brix. I found a photocoupler wich seems dead. On the top of this SMD 6 pins component, there is wrote : 4N3R. I found 4N3 serie datasheet but I can't found what's mean « R » for find similar. Could you help me pls ?
                      05-04-2021, 05:55 PM
                    • dcapper
                      Best LED's to buy from Digikey?
                      by dcapper
                      I bought some led's from digikey and they are hard to work with. Can someone recommend some good ones from Digikey for a led tv strip? The ones I have are 1510-2273-1-ND
                      03-15-2020, 02:20 PM
                    • jordanaudio1
                      Samsung TV UN60KU6270F power supply
                      by jordanaudio1
                      Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
                      My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
                      07-07-2025, 07:38 PM
