Sony kdl32s3000
  • reaper6
    • Jun 2011
    Sony kdl32s3000
    colour problem and ghosting but ceefax perfect, when you close ceefax a ghost image of ceefax will remain but will slowly disappear see link for pics http://*************/g/593/cimg0421v.jpg/
    can someone help
    thanks
  • rayrod81
    • Oct 2010
    • 205
    Re: Sony kdl32s3000
    Either a bad panel or bad T-Con board. Some of the panels in Sony TVs have had problems with the tab bonds on the LCD panel going bad. Most of the panels were Samsung but others can go bad too. This tv looks to have an AU Optronics LCD based on info from parts searches. If you can find one cheaply enough then replace the T-Con to see if it fixes your problem. If not then it could be a failed panel.
    • reaper6
      • Jun 2011
      Re: Sony kdl32s3000
      if the panels at fault wouldn't the ceefax be faulty or does it use an isolated part of the screen?
      • reaper6
        • Jun 2011
        Re: Sony kdl32s3000
        i decided to open her up to investigate and found the problem, it is the t-con board see link "http://*************/g/34/cimg0447n.jpg/"
        thanks
        • Cheesesteak
          Sony XBR-55A8G 4K OLED image ghosting/jumping around
          by Cheesesteak
          Hello All,
          Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
          I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
          I saw some people had success...
          04-18-2022, 04:35 PM
        • eccerr0r
          Sell or Shim Solar panels?
          by eccerr0r
          Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
          However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
          So now what to do with these small panels?
          I could sell them...
          Or I could shim them....
          03-29-2025, 01:07 AM
        • Carlos#2003%
          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
          by Carlos#2003%
          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
          02-15-2024, 07:52 PM
        • dkneyle
          Sony KDL-46HX850 Can't upgrade/update firmware
          by dkneyle
          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
          09-25-2024, 10:44 PM
          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 05:27 AM
