samsung y-sus repair assistance please!
  • zookeepertoo
    Dave
    • Jun 2011
    • 10
    hi, on my y-sus board 3 of the 4 mosfets (748228) have blown. I have removed all 4 and am now looking for other defective parts on the board. Strangely the area surrounding the mosfets when the board is powered up shows predominantly a - (negative) 192v and in a few places -(negative) 67v. This includes the tops of the capacitors around that area of the board. Has anybody any idea which other components to look at to find the faults now please. many thanks for looking Dave.
  • rayrod81
    • Oct 2010
    • 205
    Re: samsung y-sus repair assistance please!
    Negative voltages are most likely meant to be there. Plasma y-sustain boards put out a negative voltage to set the bottom of the waveform that is sent to the buffer boards.
    • zookeepertoo
      Dave
      • Jun 2011
      • 10
      Yes i agree in principal but should i be getting those voltages between earth and
      the metal capacitor tops? I have new mosfets ready to install but in my mind i still have a problem to resolve or they will go the way of the originals.
      For information the tv and board numbers follow.Your input is very much appreciated.
      PS50C96HDX
      850HW-YB02
      LJ41-05120A
      REV 1.3
      Thanks Again Dave.
      • PlainBill
        • Feb 2009
        • 7034
        Service manual is here, but that doesn't show the Y-Sustain, which is considered part of the plasma panel.
        There should be a white label on the plasma panel with the model number of the panel. What is it?
        PlainBill
        • zookeepertoo
          Dave
          • Jun 2011
          • 10
          hi, i thought that 850HW-YB02 was the model number. There is also this
          50HD-822841301427(03).
          Thanks again Dave.
          • zookeepertoo
            Dave
            • Jun 2011
            • 10
            This is an image of an identical board and buffers.
            • zookeepertoo
              Dave
              • Jun 2011
              • 10
              Here is a little more background info.
              • zookeepertoo
                Dave
                • Jun 2011
                • 10
                Any thoughts Bill.
                Cheers Dave.
                • PlainBill
                  • Feb 2009
                  • 7034
                  Originally posted by zookeepertoo
                  Any thoughts Bill.
                  Cheers Dave.
                  Yes. I don't know what is going on here. I've never seen a schematic for a Y-Sustain, and have only a vague idea of what is happening with them.
                  One of the problems is GIGO. A Google search for the panel model number you gave (850HW-YB02) results in only 8 hits. The actual panel number is probably S50HW-YB02. And I'm not having any luck finding more information on it.
                  PlainBill
                  • zookeepertoo
                    Dave
                    • Jun 2011
                    • 10
                    Re: samsung y-sus repair assistance please!(more info)
                    Yes i havent found much either Bill. The back panel has ca50c9 marked on it if that means something to you. I`m just going to continue searching online.
                    Cheers again.
                    Dave.
                    • rayrod81
                      • Oct 2010
                      • 205
                      Ok according to the service manual, which has very little useful information, the -190V is supposed to be there. That is the voltage at which the Vscan alignment is supposed to be. The two surface mount mosfets at the bottom of the y-main create that voltage. As to why you are reading -190V to the top of caps I couldn't tell you. Honestly, it has never occurred to me to measure the top of a capacitor. I can tell you that the three small blue caps on the board should be replaced. There are the 25V 680uf caps at C5300, C5715 and C5709. They are known failure points on these boards and can wreak havoc if they do fail. Also the 2SK2837 and B20NK50Z have been known to fail on these boards also. Usually when I have repaired these I have had to replace all 10 mosfets on the two heatsinks nearest to the buffers and the B20NK50Z. I don't know what to tell you other than that.
                      • zookeepertoo
                        Dave
                        • Jun 2011
                        • 10
                        i very much appreciate your helping me out here . i`ll keep you posted.
                        many thanks Dave.
                        • zookeepertoo
                          Dave
                          • Jun 2011
                          • 10
                          The story so far.
                          All components mounted on the three heatsinks have been removed and tested. Still only the previous three fets show as duff. The exception test wise are the two stth20p03s rectifiers (?). I am unsure how to test those.
                          I have removed and tested the electrolytic capacitors to infinty and all test good as far as that particular test is concerned alhough i do not have the equipment to properly test them. Any advice as to further tests i can perform please.
                          many thanks Dave..
                          • jettboat
                            • Nov 2012
                            • 63
                            check these locations z diode @ #5502, resistors @ 5508 & 5509, v regulator @ Q 5501 I had these fail on the same y sus, along with fet's mentioned on the two heat sinks common with this board when buffers are toasted
                            • tiny68
                              • Aug 2013
                              • 33
                              Can you confirm what the "small blue capacitors" you are referring to? Are they: C5828, C5018 and C5014 which are all marked "331k 1kV"?
                              • tiny68
                                • Aug 2013
                                • 33
                                What should the z-diode D5502 read? I get readings of 0.92V and 0.65V in each direction using the diode setting on the multimeter (tested in circuit).
                                • ohren
                                  by ohren
                                  09-08-2023, 05:24 PM
                                • C152Heavy
                                  by C152Heavy
                                  Summary for TL-DR readers:
                                  • VCC pin (18) of PFC...
                                  01-11-2023, 02:53 PM
                                  09-07-2024, 05:50 AM
                                • Nicktronic
                                  Samsung Power Supply Board BN44-00874F
                                  by Nicktronic
                                  Hey everyone,
                                  This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                  Anybody...
                                  03-17-2025, 06:20 AM
                                • Asraf Atb
                                  by Asraf Atb
                                  01-27-2025, 05:02 PM
