Pioneer PDP-504pe trap switch
    This tripped me up last year! learned the hard way, I never had a media box, just got one today, still not able to get into service menu to reset the trap. the screen did work before I messed up so should be able to get it on, have googled this for hours, if anyone can help, this is what I have tried
    media box and screen in standby
    press info button (as soon as I do this screen comes out of standby! green and red led lit)
    Wait 3 to 7 seconds (tried lots of variatons of this)
    press left.up,left, right
    power on, screen should now power on in service mode (but it already switched on first button press)
    I dont know what else to try?
    thanks Ronnie
    sigpic
    Re: Pioneer PDP-504pe trap switch
    What year is this tv?
    Do you have a video feed to this tv?
      nie
      Hi thanks for the reply, it's a 4th generation from 2005 I think? I have the media box connected to the screen but nothing else
      thanks Ronnie
      sigpic
        The service manual is available on Elektrotanya. They mention resetting the trap switch.
        PlainBill
          PlainBill
          Hi PlainBill, thanks for the link, I have read that manual elsewhere, it tells you to go into service mode and then tells you to refer to another manual to do this! but the sequence I described earlier is suppose to acheive that?
          From manual-
          ¶ How to enter Factory mode using the remote control unit
          Please refer to the technical documentation (Service knowhow).
          ¶ How to clear the detection log of the TRAP switch
          In the INITIALIZE layer, hold the OSD key on the remote control unit pressed for at least 3 seconds.
          ¶ After a power-down, to cancel detection of the TRAP switch using only the remote control unit, follow the
          procedures below.
          First, fix the TRAP switch to its depressed position. Set the drive ON/OFF switch in the DIGITAL VIDEO Assy to OFF,
          Then enter the Factory mode. Press the MUTE key four times, then hold the OSD key pressed for at least 3 seconds. Set the AC switch on
          the panel to OFF. The log is also cleared. Then set the drive ON/OFF switch to ON.
          sigpic
