Technika 15.4-310 HD ready TV
  • johnboy183
    • May 2008
    • 119
    Hi
    Not sure if I am getting older rapidly or have missed some developments but I have purchased one of the above brand new but with a broken screen. The plan was to replace the screen with a 15.4" widecreen from another tv as I have done on several ocassions with similar faults.
    However on opening this model I find there is no seperate backlight connection to the screen and I cant for the life of me find the inverter powering the screen backlights!! The cable to the screen is not simply the usual flat 16 pin connector but has two seperate rows of pins in one connector that the cable attaches to. I assume (!) that the backlight is either fed via the one cable or there is some sort of integrated inverter in the LCD panel itself. One last thing is that the panel is 13.5" wide by 7.75" deep which is not the convential 13" X8" i am used to.
    Can anyone shed any light on this mystery for me? If not I will get some photos taken to show everyone I am not delusional! - and no before someone suggests it the inverter etc has not been removed as the tv has not been opened prior to myself doing it.
    Regards
    Johnboy183
  • Scenic
    o.O
    • Sep 2007
    • 2640
    Re: Technika 15.4-310 HD ready TV
    Possibly a LED backlit panel. those don't need inverters like the CCFL backlit ones.
    look for LED backlit LCD panels with the same resolution out of dead laptops on ebay or something..
    • Dgtech
      E. Technician
      • Apr 2009
      • 1462
      • Steeler
      With this only being a 15 inch screen everything is going to be tiny and integrated. I'd bet that it's a tiny inverter section integrated or it's own board. I have a question. Since this model says "HD Ready" does that mean that this does not have a DTV tuner?
      • Scenic
        o.O
        • Sep 2007
        • 2640
        "HD Ready" usually only means that it's capable of displaying 720p (1280x720)
        (which is not a problem for this panel as it's 1280x800)
        some of the specs
        http://direct.tesco.com/q/R.206-7097.aspx
        • johnboy183
          • May 2008
          • 119
          Thanks for the replies and a little further research has shown it is indeed a LED Backlit panel!.
          Hmm so now my mix and match fixing needs to take that into account and not just the screen size. A single level of consistency would be too much to expect of manufacturers I suppose as they constantly try to bring in the next development.
          Johnboy
          • japlytic
            • Oct 2005
            • 2086
            The term "HD Ready" seems to confuse a lot of people, since some assume that it has a HD digital tuner.
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
            • Chrissygizmo
              by Chrissygizmo
              02-10-2025, 12:33 AM
            • spice_disc
              Vizio TV M50-C1 reboot cycle and static on screen
              by spice_disc
              I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
              The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
              09-08-2024, 02:37 PM
            • ipatch
              ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
              by ipatch
              i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
              08-24-2024, 02:36 PM
