dell 2000fp monitor
  • rquig
    • 6
    dell 2000fp monitor
    I could use some advice on what to do next in trouble shooting the dell 2000fp monitor.
    symptoms: When power is applied I get a white flash on the screen and then it goes blank.
    What I have done: I tried to get a response from the brightness or contrast buttons -- Nothing. I removed case and tried to find a obvious component failure or burned spot -- nothing. I checked the f1 fuse -- It checked good.
    I am not sure where to go for the next step, help would be appreciated.
  • alexanna
    • Mar 2010
    • 1346
    Re: dell 2000fp monitor
    There is an older thread started on the monitor you're working on, and I think it might be similar problem as you have.
    This thread might help
    https://www.badcaps.net/forum/showth...ghlight=2000fp
    • rquig
      • 6
      Thank you I have looked at that thred and it is similar, infact it is what gave me a starting point. That said, I don't have the same symptomx and I don't have any obvious singns of component failue. I get a white flash for about 2 seconds and then nothing.
      • alexanna
        • Mar 2010
        • 1346
        There are so many things that can cause what I think you may be talking about.
        What are the LEDs doing on the front of the monitor?
        Are you sure that the external power supply, can produce the amperage required for the monitor?
        • rquig
          • 6
          the video source diode is on and can be changed to select source and the main power supply diode is on and can be turned off and on. everytime the monitor is turned on you can see the white flash. The diodes are both green in color. what amperage should this monitor require? I'm not sure that it has the right power supply.
          • alexanna
            • Mar 2010
            • 1346
            The specs. of the powersupply needed are usualy on a sticker on the rear of the monitor
            • jetadm123
              • 2169
              Please post some clear focused photos of the entire power supply, top and bottom, since power supplies from different companies were used on this model.
              • rquig
                • 6
                Thanks to you focusing my attention on the power I have discovered that the supply amperage is only .3 while the monitor requires 3.5. The voltage is correct.
                • alexanna
                  • Mar 2010
                  • 1346
                  Yep you need to get the correct power supply.
                  I have repaired two of these, and I was not happy with the picture the best way I can describe the problem is that it looks like I am looking through a screen door. I don't know if something else is wrong or it's just normal for this monitor.
                  • rquig
                    • 6
                    I got the new power supply cord . plugged it in and the monitor started working just like it was supposed too!!!! Thanks again
                    • alexanna
                      • Mar 2010
                      • 1346
                      That ill get ya every time,Glad you got er going
                      Al.
                      Oh how dose the pitcure Look.
                      • Borse2008
                        by Borse2008
                        • There’s
                        07-15-2025, 04:55 AM
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • DanPoka
                        by DanPoka
                        02-15-2025, 05:05 AM
                        by momaka
                        03-15-2023, 10:17 PM
                      • Jesus Coder
                        Issues Reviving Old Dell 2408WFPb Monitor
                        by Jesus Coder
                        I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
                        06-25-2023, 02:33 PM
