Hi and thanks for the admin for letting me be part of this forum.
I have a Digital Lifestyles LCD TV, model : LT26407. It doesn't turn on. When you connect the cable to the outlet, you can see that current is there because the standby red light is on, but when I hit the Power Button, the red light blinks to green for a fraction of a second, (goes back to red) and hear a realy click inside the TV.
I did a search on Google and found out that the problem is bad capacitors in the power supply. I removed the back of the TV and took a look at the power supply seeing that 7 CapXon capacitors ( 1000uF, 16V) are domed shaped on top of them. I measured them and according with the rule they are 10mm diam. x 20mm tall.
That site recommend to change them but a higher voltage ones because heatsink is pretty close.
I live in Puerto Rico, Caribbean Sea and ambient temperature is from 80-100 degrees F.
I did a search about caps characteristics and saw the good and bad capacitors manufacturers.
Taking into consideration ambient temperature and quality, should I stick with good brand name caps staying in the 16V or should I pay attention to the recommendation to replace them with higher voltage ones but cheapo brand names.
Here are the options I have to buy 10 caps bag on ebay:
Brand Voltage Size (mm) Price
Fuhjyyu 25V 10x20 $ 6.00
No brand displayed 25V 10x15 $ 6.50
Sanyo (Ultra Low ESR) 16V 10x16 $ 6.00
Nichicon 16V 10x13 $ 6.00
Rubycon 16V 10x20 $ 13.00
The seller of the Rubycons is in US, the other sellers are in China.
According with you knowledge and experience, should I go for the higher voltage bad manufacturers caps or should I stick with the 16v good manufacturers caps?
I include pictures of the power supply for you to see the bad caps.
thanks.
thanks.
