Viore 26" LCD TV Backlight Inverter issue
  • itek
    • Aug 2010
    • 65
    Hi everybody, I have a 26" Viore LCD here Model LC26VH55. It was showing a picture and rapidly flashing the backlight for awhile now its just dark. I can see it is displaying images with a flashlight. So I'm guess i'm in for a new inverter board right? the one inside is stamped CMO I260B1-5UC-A001B / T87I027.09 / 27-D024386. Do I have to replace with the exact board or can I switch to one thats close like this one:
    http://cgi.ebay.com/VIZIO-VA26L-BACK...item56436069ebf
    its very close just wondering since I am so new at this,
    Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Viore 26" LCD TV Backlight Inverter issue
    If you are going to be a regular member here, please use the manage attachments feature to upload your picture and please do not post inline. There are several reasons why as stated below
    https://www.badcaps.net/forum/showpo...5&postcount=12
    --- begin sig file ---
    --- end sig file ---
    • itek
      • Aug 2010
      • 65
      OK sorry I didn't know how to do that, will do from now on!!! Thanks retirecaps
      • retiredcaps
        • Apr 2010
        • 9271
        1) Did you check to see if there are any SMD fuses on the inverter board? If yes, do the fuses measure less than 1.0 ohms?
        2) Did you check the secondary inverter transformer pins to see if the ohms readings are within 3% of each other?
        • itek
          • Aug 2010
          • 65
          will check and report back asap, thanks again
          • itek
            • Aug 2010
            • 65
            OK it seems there are 3 SMD fuses on the board although they are labeled F2-F4, they all report 0 ohms resistance.
            Each transformer reports back very close, definitely within 3%.
            • retiredcaps
              • Apr 2010
              • 9271
              If I were designing a board, I would starting numbering with 1. That said, check for a F1.
              • itek
                • Aug 2010
                • 65
                OK I found it - F1 0.75A / 76V, test 0 ohms,, the other 3 are white this ones black it was blending in
                • retiredcaps
                  • Apr 2010
                  • 9271
                  1) Your photos are too low in resolution to see the part number, but try checking the 8 pin IC for shorts. You will have to read the part number and look for its datasheet.
                  There are 6 of them. There are 2 ICs "sandwiching" each of the 3 caps on the inverter board.
                  2) What brand and make are the caps. You could try changing them?
                  • itek
                    • Aug 2010
                    • 65
                    OK the mosfets are AO4614, I'm new at this and trying to decipher the datasheet on how to test them. is it "Static Drain-Source On-Resistance" or "Gate Resistance" i'm going for? My multimeter is a fluke 179 and always wants to "auto range" is this ok or should I always set it manually?
                    The caps are as follows:
                    1. (no name?) KZH 35v 390uf
                    2. Nichicon HV 35v 270uf
                    3. Rubycon ZLH 35v 390uf
                    Thanks,
                    Jared
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      See section on MOSFETs at
                      https://www.badcaps.net/forum/showpo...0&postcount=13
                      Nice multimeter! Leave it at auto.
                      KZH is made by United Chemi-con (brown sleeve with a little "crown" symbol).
                      All 3 caps brand and series above are quality low ESR as per
                      https://www.badcaps.net/forum/showthread.php?t=2280
                      • itek
                        • Aug 2010
                        • 65
                        thank you very much retiredcaps for being so helpful, i'll check the mosfets tomorrow morning an post results.
                        • Cornito
                          Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
                          by Cornito
                          Hello Team,
                          I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
                          Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
                          Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
                          08-08-2024, 08:09 AM
                        • cheebster
                          iPad Pro 12.9 5th Gen Backlight Issue
                          by cheebster
                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                          Anyone...
                          05-20-2025, 09:17 AM
                        • Acnologia
                          Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
                          by Acnologia
                          Hello to all members of badcaps.
                          Another brainstorming that i have been messing with for months as a side project.
                          Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
                          I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
                          Step 1.
                          Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
                          Machine > Doesn't give display it's really dim.
                          Step 2.
                          Use the same...
                          11-05-2025, 04:02 AM
                        • Cornito
                          TCL 65C715 backlight issue
                          by Cornito
                          Hello team,
                          I'm back with another topic.
                          It's a 65C715 TCL tv with backlight issue.
                          But the problem is a bit strange.
                          When I took this tv from the marketplace backlight didn't work but picture was ok.
                          Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
                          Putting all back together the tv worked fine for weeks. => Contact issue??
                          Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
                          06-09-2024, 02:24 AM
                        • shellybelly
                          Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
                          by shellybelly
                          Back Story
                          I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
                          So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
                          08-27-2023, 10:40 PM
