lg 32lc2d no picture
  • terry681
    • Mar 2011
    • 38
    i have a 32 lcd tv as i was given it and as usall i had the idea the caps on the psu board had gone and sure enough c208 was bulging and L201 was stuck to that cap slightly melted and so from reading other posts i went ahead and replaced all the caps except for these the big middle one c150,c500,c501,c502.
    the symtoms are green led on set flashes 6 times tv lights up showing av1 then changes to no signal and the screen lights up as i can see it from the back of the set lit up.
    ive olso noticed that 3 red smd led light up on the main board.
    i hear olso the set clicking 3 times on start up from the relay i hope i have explained this right as im not a tv repaire guy just a tinkerer and messing about with the tv past my time .
    so any help would be great from ppl that are more clued up that me in fixing these type of lcd tv.
    and if i could olso ask when i want to check voltage at the psu for voltage using a dmm where should i be placing the probes when checking the p203,p202,p201.
    and i know that a few may say if not sure in checking voltage get a pro but its somthing for me to do and if i can get it up and running then ill be well pleased but if not then so be it and great site and a big thank you to all the ppl that make this a cracking site .oops ill post pics when i work out how to sorry for not getting them up.
  • PlainBill
    • Feb 2009
    • 7034
    Re: lg 32lc2d no picture
    Note links to taking pictures in my signature. There is a maximum size of 2000 x 2000 pixels. Use 'Manage Attachments' below the text entry area to attach pictures.
    My question is "What happens if you hook a signal source to AV1?"
    PlainBill
    • terry681
      • Mar 2011
      • 38
      and olso sorry should have stated the controls on the tv dont fuction and the remote is the same.
      • terry681
        • Mar 2011
        • 38
        could some one tell me how many smd red led are on the main board of the 32lc2d the middle one.
        as i can see one light up when in stand by but when tv is turned on 2 other led come on the thing is ive noticed what looks like another led up at the left hand top corner as this fails to light up could this be bad and give the symtoms im getting i done more volt testing does it look the right voltages for these p connectors etc p102 p103.
        these are on the main board these results.
        cn500 connector
        1.3.3v=1.09v
        2.3.3v=1.09v
        3.6.05v
        4.6.05v
        5.11.68v
        6.11.68v
        p500
        1.5.11v
        2.3.18v
        3.5.06v
        4.4.86v
        5.this pin drops its voltage (err)
        6.0.45v
        6.5.06v
        7.2.01v
        p1311
        1.led g. 0 v
        2.led r. 2.82v
        3.5.00v
        4.4.97v
        5.3.34v
        6.3.35v
        power supply volts
        p202
        1.19.20v
        2.19.20v
        3.6.06v
        4.1.09v
        5.11.71v
        p203
        1.1.09v
        2.1.09v
        3.6.05v
        4.11.69v
        5.11.69v
        as im starting to think maybe the main board has went bad or im way off the base thanks all for looking.
        • terry681
          • Mar 2011
          • 38
          a wee pic of the 3 red led on the main board. just need to find the correct manuel for this tv, main board it states its a ld61 iv been reading a ld51 manuel think it is and couldint find this small led on the parts page and the schematic what a plum i am ehh well still learning and again cheers for looking at my issue.
          • terry681
            • Mar 2011
            • 38
            its actually 2 led that fail to light up i think they should light up.
            • terry681
              • Mar 2011
              • 38
              been messing around with the set and found that i get 0.00 at both ends of smd resistor
              r304 with the marking on it 000 and Q301=3.26 and 3.29. and led 300 =0.38 and 0.25-26
              should i be seeing a voltage from this resistor i think so but im new to electronics and still learning .
              • terry681
                • Mar 2011
                • 38
                well still no reply any way got it sorted myself well netdent made a suggestian av board
                well sir u was right a 3 pin diode on the solder side of the av board next to jk 100 or its jk101 the scart connection pin 16 cheers any way all.
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • JJAAMM
                  by JJAAMM
                  Problem
                  07-06-2023, 06:01 AM
                • TR103
                  by TR103
                  - it keeps rebooting
                  01-22-2025, 04:12 PM
                • Mgiffune
                  by Mgiffune
                  06-09-2024, 10:28 AM
                • CyberPhoenix
                  Issue with picture quality of Sony bravia TV
                  by CyberPhoenix
                  Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                  01-22-2024, 02:08 AM
