Sanyo 50" Plasma TV Model DP50747
  • BLUE1999P38
    • 7
    I bought the Sanyo to see if I can repair it. It has a group of vertical lines slightly to the right of the center of the screen. from left to right, The first one is about 1 inch wide and black, then a 1/8th inch wide purple line, then a one inch wide snow line, then a 1/8th inch wide green line, then a 1.5 inch wide black line. The "snow" stripe maybe not a stripe because I donot have the cable connected and the screen is snow. I have seen several posts about these TVs power supply problems and horizontal lines but nothing so far on vertical stripes. Can anyone offer a suggestion?
    thanks
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sanyo 50" Plasma TV Model DP50747
    Yes, it's either a bad driver chip, a bad panel, or a bad main logic board. A picture is worth 1000 words. Rather than supplying the additional 840 words, just attach a picture.
    PlainBill
    • BLUE1999P38
      • 7
      thanks. Heres the photos of the screen
      • PlainBill
        • Feb 2009
        • 7034
        Definitely drivers, and may or may not be repairable. Here is what I understand. It depends on how the plasma panel in that set was made. Some panels have the X-drivers on a separate board. Others bond the drivers to the plastic ribbon connected to the panel. If it's a separate board, the board can be replaced. If it's bonded to the ribbon, it's virtually impossible to replace the defective chip.
        PlainBill
        • BLUE1999P38
          • 7
          would posting a photo of the parts you mentioned allow you to determine if the drivers are on the ribbon or on the board?
          thanks
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Yes. A photo of the rear of the panel will help.
            A working TV? How boring!
            • BLUE1999P38
              • 7
              This photo is with the back off and the plate that covers the Logic Buffer boards removed. The area I photographed is the lower edge of the left side. the item is marked Model No. 50' HD W3 Logic Buffer E - PCB No. LJ41-05512A.
              I see the part for sale on a couple of online TV parts suppliers. Is this part the driver you were referring to?
              Thank you
              • PlainBill
                • Feb 2009
                • 7034
                Thank you
                Yes, but you are getting into an area I've never explored. You can see the construction better than I can. If you remove the screws, can you carefully lift the E board and photograph the back side? I don't see any obvious decoders / drivers in the picture.
                Note that if someone older (our younger) and smarter than I says "Don't do it!!", listen to them.
                PlainBill
                • BLUE1999P38
                  • 7
                  Thanks for the reply. I am not shy about working on electrical components but this is something I've never worked on. So I need the guidance. I attached several photos because I am not sure of the quality. All are taken with the board flipped up to view the back of it. The gobs of white on each ribbon are greasy. It is difficult to see in the images but there is a component (?) embedded in each ribbon on the front side and the greasy stuff is directly behind it.
                  thanks again
                  • PlainBill
                    • Feb 2009
                    • 7034
                    thanks again
                    That pretty much confirms it in my mind. The driver is bonded to the ribbon cable. Again, I have no personal experience with these, but Wizard reports that the drivers cannot be replaced, and I respect his experience.
                    PlainBill
                    • rayrod81
                      • Oct 2010
                      • 205
                      Yeah that panel is most likely junk. When the driver chips are bonded to the ribbon it cannot be fixed without specialized equipment.
                      • BLUE1999P38
                        • 7
                        is this what you're talking about?
                        http://www.fps-europe.com/repair.html
                        • BLUE1999P38
                          • 7
                          Here's a guy soldering the TAB connection by hand!
                          http://www.youtube.com/watch?v=Z99P0...layer_embedded
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Yes but he has a PCB there. That's easy to do. When both sides are plastic however... you're outta luck.
                            • Scenic
                              o.O
                              • Sep 2007
                              • 2642
                              the problem is usually the connection from the flexcable to the panel itself, not the soldered connection to a circuit board.
                              you can't reattach the flexcable to the glass panel without special equipemt unfortunately
                              • madmike56
                                • Jun 2011
                                • 5
                                can anyone help me with this sanyo dp57047?
                                no sound or pic; just a click from the board pic from the top middle board and 1o seconds later another click. I really need to fix this so the wife doesn't kill me for buying it.
                                • PlainBill
                                  • Feb 2009
                                  • 7034
                                  Don't double post.
                                  PlainBill
                                  • rubencanales
                                    • Feb 2012
                                    I am a newbe. Had my Sanyo dp50747 repaire just before my extended warrenty ran out then not long after it just would not turn on. Tried unpligging ang replugging the power, the cable no luck. Is ther an on-off switch that I can replace? I am willing to try anything.
                                    • PlainBill
                                      • Feb 2009
                                      • 7034
                                      Almost certainly not a problem with a physical switch.
                                      Do you have a DMM? A camera? How about a philips screwdriver? Soldering iron?
                                      Remove the back of the TV. Take one sharp, well lit picture showing the entire back. This picture should be close to but not over 2000 pixels on a side. Attach the picture to your next post using 'Manage Attachments' - below the text entry area.
                                      PlainBill
                                        ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook Specification for Upgrade or Repair
                                        This specification for the ASUS 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard / To boardview and 14.0 FHD 1920X1080 16:9 non-Touch Wide View / 7505 / Intel UMA / 4GB / 128GB PCIE G3 SSD / WIN10 HOME S / N/A /Chiclet Keyboard...
                                        09-07-2024, 02:50 AM
                                      • canadaboy25
                                        Sanyo DP5749 Plasma won't power up
                                        by canadaboy25
                                        Hey everyone,
                                        I was given a Sanyo DP5749 Plasma that has failed. The symptom is the TV tries to start up and shuts back off about 3 seconds later. With the service manual I was able to determine that the TV is shutting down due to detecting a missing power rail. The 5V supply to the logic board is okay at startup but after a second it disappears. The TV shuts off shortly afterwards.
                                        I traced the problem to a 3.3V enable signal from the D board to the power supply. This signal disappears for some reason which shuts a few power rails on the PSU off. The signal comes...
                                        02-01-2021, 01:19 PM
                                      • MagicSmoke
                                        Older Sanyo DP50747 VE Voltage High
                                        by MagicSmoke
                                        Working on an old Sanyo 50" that has Samsung innards. Backstory.. saved from dumpster years ago, partial recap on SMPS, Replaced one of two small caps on X-main, set worked great for about 3 years.
                                        Then recently it started to take a few minutes from power on to display a pic and sound, worked like that for about 3 months, then Smps would click once and then nothing, it will not shut itself off but nothing happens.
                                        So pulled PS replaced all the caps, even the large mains. PS works and has all stable rated voltages present when switched on. TV has sound (static) when...
                                        12-02-2020, 11:56 PM
                                      • glutton4punishment
                                        Static/Snow Picture on Hitachi Plasma P50X102A
                                        by glutton4punishment
                                        Hi!
                                        I'm trying to fix this TV (duh!), thanks for your help!
                                        The image has an overall white cast to it with purple and green areas of hue, and lots of snow when there's no input. With input, the image looks like a blend of the image and the the white/green/purple/snow background.
                                        The menus and error message ("no input signal") appears on the screen very clear without problems. The menu and error message appear in a navy blue box with yellow letters, or a black box with yellow letters and a red exclamation point.
                                        All caps/components...
                                        03-03-2020, 07:08 AM
                                      • ArMaaN376
                                        Samsung PS51E550 Plasma TV
                                        by ArMaaN376
                                        I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                                        Opened TV cover & observed foll
                                        a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                                        b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                                        c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                                        How to confirm Y -Buffer board...
                                        06-19-2024, 04:05 AM
