When plugged in the amber LED flashes 8 times (pattern changes every time I plug it in). I have 5V and 12V.
When powered, LED turns green, after approx. 15 sec. the back light comes on and screen is white/grey. I have 5V ,12V,3V on/off and 3V dim. so P.S. seems to be working.
Buttons appear to work,I have sound and can hear when channels change. When I change inputs to AV1 I have sound.
When powered down LED flashes amber (random patterns) back light shuts off and LED is solid amber.
No parts appear bad or damaged, checked for bad solder joints. Only 5 leaded caps.I checked for shorts and used diode checker in area of cable to panel. I do not have an ESR meter and have not removed any parts to check, all in circuit so far.
Any ideas where to start ?(other than replace M.B.)
It sure be nice to have separate T-Con board
Any ideas where to start ?(other than replace M.B.)It sure be nice to have separate T-Con board
I guess I did not look close enough last time .I found the T-con board! I didn't have much time to check it out . Visual looks good ,fuse good,o ohm res. good . I am open to ideas.
