Insignia NS-LCD19 no picture but has back light and sound
  • 1simtime
    • Feb 2011
    • 30
    Re: Insignia NS-LCD19 no picture but has back light and sound
    Timed out so I could not add to last post
    Removed R67 short is gone at C1.
    C34, C35 still 2.2 Ohms.
    Q4 top leg to bottom left =15 Ohms
    Q4Top to bottom right(goes to GND) =2.2 Ohms
    Readings keep changing for all below
    C20 .821M /280K Ohm
    C23 314K Ohm
    D3 - to anode , + to cathode = 172 Ohm
    D3 + to anode , - to cathode = 119 Ohm
    D2 - "........ " , + " ........." = 483K
    D2 + "........ " , - " ........ " = 506K
      master hoarder
      • May 2008
      • 12170
      Okay... so D2 and D3 are good.
      Most likely Q4 is bad, but I think it would be easier if we start with C34 and C35 since they have 2 leads only - remove C34 and measure resistance either across C35 or across the pads where C34 was on the board.
      - If 2.2 Ohm resistance is gone, check resistance on C34 out of circuit. A good ceramic capacitor will show infinite resistance out of circuit. If C34 doesn't, then it's bad.
      - If 2.2 Ohm resistance is still there, remove C35, and repeat the same procedure you just did for C34. And if the 2.2 Ohm resistance is still there or if there is 2.2 Ohm resistance between top leg and bottom-right on Q4, then remove Q4 and measure resistance again across the various legs of Q4 out of circuit.
      • 1simtime
        • Feb 2011
        • 30
        Removed C34 good and C35 good.Still had 2.2 Ohms on board.
        Removed Q4 (lower right leg where 2.2 ohm was came off) part was already heat damaged . Measured 27 Ohms on lower left.
        2.2 ohms gone on board. So looks like Q4 is bad.
        • 1simtime
          • Feb 2011
          • 30
          If you think BCX70H will replace the NAH3, I found it at Digikey.
          Here are the resistance readings for D1 I took before Q4 smoked.
          looking at pic 3973 I used top left as pin 1 and went clockwise to 6
          I used na for readings that changed .
          +1 to -2=na........-3=na.......-4=na.....-5=na......-6=na
          +2 to -1=.823M...-3=na.......-4=na.....-5=na......-6=na
          +3 to -1=pulsed...-2=open....-4=na.....-5=na.....-6=na
          +4 to -1=pulsed...-2=pulsed..-3=287K..-5=na.....-6=na
          +5 to -1-.779M...-2=.590K....-3=472K..-4=285K..-6=na
          +6 to -1=.285K...-2=515K.....-3=1.102K.-4=.985K..-5=na
          D1 today with C34,C35 and Q4 removed
          +1 to -2=277K......-3=.844M...-4=.724M...-5=.409K....-6=.798M
          +2 to -1=.795M.....-3=521K....-4=411K.....-5=1.43K....-6=.477K
          +3 to -1=pulse......-2=pulse....-4=open.....-5=open.....-6=open
          +4 to -1=pulse......-2=pulse....-3=270K.....-5=pulse.....-6=pulse
          +5 to -1=724M.....-2=pulse.....-3=269K.....-4=267K.....-6=456K
          +6 to -1= 268K....-2=494K......-3=1.047M..-4=.859M....-5=536K
          All the readings seem to change .That is why I did not post the 1st readings earlier.
            master hoarder
            • May 2008
            • 12170
            Yes, unfortunately.
            I can't say for sure since I'm not that well versed with transistor replacements. If no one else posts an answer to this in a day or two, then feel free to open a new thread in the General Electronics forum. Just ask what would be a suitable replacement for the NAH3 transistor and put a link to this thread.
            I have a few other ideas/solutions for the TV, but it's probably better to use them as last resort only since I can't be sure they will work, and they do involve a certain risk (as in, they may further damage the t-con if they don't work). So if you get to the point where you don't care about the TV and just want to try anything to get it working, I'll post them.
            Meanwhile, you can reinstall R67, C34, and C35.
            As for readings on D1, you need to use either 2000 Ohm scale or diode test function (assuming you have a manual-ranging digital multimeter). The reason for this is because diodes require a certain amount of current to conduct in the forward direction (red probe on anode, black probe on cathode). The diode test function is designed to supply this current, which is why it's usually a good idea to test diodes with it (note: on common digital multimeters, the diode test function is usually coupled with the continuity check). Also, on most digital multimeters, only the 2000 Ohm scale will be able to supply this forward-biasing current to test diodes. 200 Ohm scale can too, but diodes usually have a resistance in the 100 to 1000 Ohm range in the forward direction, so not all diodes will display a proper readings on 200 Ohm scale.
            Now, I didn't see any short-circuits on D1, so it's probably okay. But if you want to retake the readings with either diode test function or 2000 Ohms, scale, I still wouldn't mind taking a look at the results.
            • 1simtime
              • Feb 2011
              • 30
              #26
              I have information on Q1 marked NAH3.
              I will try to locate data sheets for D1 marked DNc
                master hoarder
                • May 2008
                • 12170
                #27
                N-channel MOSFET - seems right for this application, as per the FP5138 datasheet.
                Make sure to buy at least 3 of them (I'd say 5 is a good number), just in case. Or if you can't find this exact MOSFET, just find another one with similar characteristics. Tech support at Digikey or Mouser should be able to help with that.
                • ButchPor
                  • Nov 2012
                  I have looked over this thread and have the same problem, however, all of the TV and HDMI inputs work if the Monitor is cool (power off for a couple of hours), I can bring up the menu, the images are fine. However, once it warms up the screen goes blank but the back light and sound continues.
                  Any ideas that are more specific or should I follow this thread
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                  • MOSSEP
                    Monitor Audio RSW12 - Green light, but no sound
                    by MOSSEP
                    Hi
                    Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                    Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                    The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                    I have already tried replacing all of the...
                    01-26-2025, 08:33 AM
                  • dronerat
                    Samsung UE48JU6400W - back light on, sound on, sometimes picture.
                    by dronerat
                    Hi Guys,
                    This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
                    PSU: L48S6 FHS BN44-00807D
                    T-Con: BN95-01937A
                    Panel: CY-GJ048HGLVLH
                    MB: NA (Currently as the TV is assembled and forgot to take picture)
                    As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
                    It was sent to an authorized service for repairs and returned with the...
                    05-15-2020, 08:03 AM
                  • koby058
                    vostro comes up with back light but no picture
                    by koby058
                    Hi people!!
                    The owner said it showed bad picture once in a while (attached)
                    I see that there is back light but no picture.
                    I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
                    Also attached schematic and BDV
                    LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
                    07-13-2025, 01:03 PM
                  • kca
                    Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                    by kca
                    Hello all ~
                    I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                    This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                    No picture. No sound.
                    I tested all the voltages coming out of the power supply...
                    10-12-2023, 05:23 PM
