Philips 32PFL3403d/27 LCD NO POWER
Re: Philips 32PFL3403d/27 LCD NO POWER
Thank you. Well, this proves my ability to multitask is severely lacking.
I REALLY have to apologize. I've screwed up badly. TechFab.fr has provided the service manual, and it even includes a schematic of the power supply. Perhaps that can provide some badly needed information. I'll get back to you tomorrow.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
I have a few points for you to verify, and then PERHAPS we can come up with a rational answer. In one way, this is frustrating. In my experience, Philips Service Manuals have a great deal of information about the main board, virtually nothing about the power supply. This one is the opposite.
Configuration: Hook the boards together as they would be if the TV was in normal operation and use at least two mounting screws to hold each of them in place. Locate U152 on the main board; it should be close to the power input connector. Set your DMM to the 20V DC range.
Plug in AC power and measure the voltages on each of the pins of U152, using one of the mounting screws as Ground (the tab is electrically connected to the middle pin). If the pins are at the bottom, the voltages should be 0V, 5.1V, and 3.3V. Report the voltages.
Next, on the power supply, measure the voltages at IC905, pin 4 and CN902, pin 10. Report the voltages.
I wonder if we can find some info on that main board, perhaps a different service manual. I can find the number of that board.I have a few points for you to verify, and then PERHAPS we can come up with a rational answer. In one way, this is frustrating. In my experience, Philips Service Manuals have a great deal of information about the main board, virtually nothing about the power supply. This one is the opposite.
Plug in AC power and measure the voltages on each of the pins of U152, using one of the mounting screws as Ground (the tab is electrically connected to the middle pin). If the pins are at the bottom, the voltages should be 0V, 5.1V, and 3.3V. Report the voltages.if the pins are at the bottom, the voltages read: leftpin=0V, the middle pin =3.28V, the left pin is 5.13V
Next, on the power supply, measure the voltages at IC905, pin 4 68V and CN902, pin 10 2.1v . Report the voltages.
PlainBillComment
That is a good idea.
In the meantime, I neglected to give proper instructions. IC905 is on the hot side of the supply, so you can't use chassis ground. Use
IC905, pin 3 as the ground point. I would like to see the voltage at IC905, pin 4 and each end of R947.
With pin 3 of IC905 as ground I get 9.1V across pin 4. I used the same ground (pin3) to measure the voltage on R947: 17.6 on one side and 17.4 on the other.That is a good idea.
PlainBillComment
Al right!!! At last some readings I can understand.
Earlier you had read the voltage at R947 as about 8 volts, much to low to start the main SMPS controller. The problem was that there was no load on the output of the standby SMPS. With the load presented by the main board's standby circuits the voltage at R947 went up to a reasonable value.
Earlier I had indicated I felt the voltage from the main board on CN902, pin 10 was too low. That pin must go high to turn on the main power supply. When you drove it high with a 3 volt supply, IC905 did turn on. Clearly, it is not turning on with a lower (2.2?) input voltage.
Conclusion: The power supply is OK, the main board is bad.
NOW, eBay auction # 250853694866 is for one of the boards at $62. The listing also includes a number of different TVs that use this board. That listing might be the starting point for a search for a Service Manual that has the schematic of the board.
I'm not optimistic. For some reason Philips made a majot change in their service manuals. There are several possible reasons, including that there are very few replaceable parts on the main board (other than the LDO regulators).
Here are the economics as I see it. There's a 5 year old Philips plasma TV in my wife's office. That TV went out of production 4 years ago, and sold for $1600. The plasma panel and the support boards were purchased from Samsung; Philips designed the 'Small Signal Board' (main board) and audio amplifier. It included a self diagnostic function. If a $1600 TV failed, they wanted to give a tech a decent chance of repairing it by troubleshooting to the component level.
Now the technology is more mature. The main board in your TV is less than 1/3 the size of the SSB in the 5 year old plasma, and is more complex. But a 32" LCD TV sells for as low as $200. At that kind of a margin, most service shops would have to do a board replacement.
Now, we here are exceptional. Spending a couple of hours to find a shorted diode makes sense if it means we don't have to buy a $100 board. But the Techs Philips cares about don't care if schematics are available.
You have to follow the link that is about in the middle of the page (below the listed models), that will take you to another screed to do the actual download.
I was able to get a bunch of manuals there. If this one isn't the right one, then there are others.
here is the link:
http://english.electronica-pt.com/el...hp?find=LC8.1U LA
let me know if you get it.
TTYL Mach1Comment
It's downloading now. Thanks for the tip.You have to follow the link that is about in the middle of the page (below the listed models), that will take you to another screed to do the actual download.
here is the link:
TTYL Mach1
<EDIT>
Well, bad news, good news, bad news.
It was the wrong service manual.
HOWEVER, thanks to TechFab.fr, I now know the chassis number of your TV. Examining the manual he linked to, I realized a large number of pages were missing. Searching Elektrotanya, I found the complete service manual (two of them, actually).
But I'm going to be too busy to do much with them for a few days.
PlainBillLast edited by PlainBill; 08-20-2011, 05:08 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Thanks for your patience. U500 is the standby processor. I'm going to have you check a few points on the board and see if we can figure out what is going on.
The first point to check is U500, pin 1 (U500 is the 44 pin square IC next to the RCA connectors). It should be at 3.3 volts (U500, pin 2 is Gnd). Next, check the voltage on U500, pin 43. Report the voltage. If it is below .5 volts, stop.
If everything is good so far, check the voltage at U500, pin 30. That drives the devices that drive pin 10 on the power supply.
And last, check the voltages on each end of R140. R140 is on the back side of the board.
What should I use as ground for R140? Incidentally I measured 1.3V across the resistor. (end to end)Thanks for your patience. U500 is the standby processor. I'm going to have you check a few points on the board and see if we can figure out what is going on.
The first point to check is U500, pin 1 (U500 is the 44 pin square IC next to the RCA connectors). It should be at 3.3 volts (U500, pin 2 is Gnd) its 3.3V . Next, check the voltage on U500, pin 43. Report the voltageIt is also 3.3V. If it is below .5 volts, stop.
If everything is good so far, check the voltage at U500, pin 30 it is 0.05v practally nothing . That drives the devices that drive pin 10 on the power supply.
PlainBillLast edited by Mach1; 08-22-2011, 06:09 PM.Comment
Use the negative lead of C505 (the thru-hole electrolytic cap on the top of the board in that area) for ground.
All of the readings look good. I'm going to have to examine the power supply schematic, the 1.2 volt drop across R140 seems to be excessive. Measure it, it should be 2.2K
Update: I looked at the schematic, and the voltage drop across R140 IS excessive. The effective resistance of the input into pin 10 on the power supply should be in the order of 150K ohms.
I hope you still have your 3V 'power supply', and a 2.2K resistor handy. Hook one end of the 2.2K resistor to pin 10 of the power supply connector CN902, the other end to the positive lead of the 3V supply. Apply AC power to the supply and measure the voltage drop across the 2.2K resistor. Report it.
There are several components that can be responsible for the excessive load, one on the main board, two on the power supply. This will tell us where to look.
Well, I had to do some rigging, and this is what I did. I left everything connected, and tapped into the CN902 pin 6 for ground (the negative side for the power supply) and connected my 2.2k resistor to the (+ side)3v power supply, and tapped into pin 10. Then tested the voltage across the 2.2k with the ac power on by connecting the DMM on eiter side of the resistor. The reading is 0.57VUpdate: I looked at the schematic, and the voltage drop across R140 IS excessive. The effective resistance of the input into pin 10 on the power supply should be in the order of 150K ohms.
PlainBillComment
I'm trying to get my head around this, but to me that .57 volt drop is excessive, so further tests will be necessary. These may be easier.Well, I had to do some rigging, and this is what I did. I left everything connected, and tapped into the CN902 pin 6 for ground (the negative side for the power supply) and connected my 2.2k resistor to the (+ side)3v power supply, and tapped into pin 10. Then tested the voltage across the 2.2k with the ac power on by connecting the DMM on eiter side of the resistor. The reading is 0.57V
Connect the main board to the power supply, then hook up AC power. Measure these voltages across R931, R932, and R943 on the power supply. Those three resistors carry the loads on the STBY pin. HOPEFULLY only one of them will have a significant voltage drop. If that is the case, stop and report your results.
If all three showed a very low (less than .2 volt) drop, disconnect AC power, then isolate pin 10 of CN902 from the cable connecting the power supply to the main board. You can do that either by cutting the wire, or preferably, releasing that wire from the plug. Then hook up AC power and measure the voltage at CN100, pin 10 on the main board. If the main board is fine, you should read very close to 3.3 volts.
PlainBillLast edited by PlainBill; 08-24-2011, 02:41 PM.For a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Sorry I was gone for a while....I didn't detect much of a voltage drop across R931,932 and 943. So I unplugged wire 10 from CN902, tested the voltage of #10 pin on CN100, (to pin 6 for gnd) with 2.1V.I'm trying to get my head around this, but to me that .57 volt drop is excessive, so further tests will be necessary. These may be easier.
PlainBillComment
Assuming...7 Photos -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by spantorHello partners.
Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos - Loading...
