First off I'd like to say reading a lot of past threads have given me a better understanding of what to look for and the inner workings of my TV, but here is my issue.
My TV set won't power on, I mean no display led, blinking ... nothing. So I went online to see what others were doing to fix their LCD. To make a long story short most individuals said the caps were bad, but not all would be, just the blown out and leaky ones. The only problem with this diagnosis was that I didn't have any bulging, leaky caps, at least not on the power board. So I just replaced the CapXon caps on the power supply board.
The TV didn't power on but I got a momentary flash off the inverter board, so I decided to check it out. After i took off the housing over the inverter board I saw that the two caps on it were bulging and leaking (the two purple caps in the photo), so I replaced those as well.
The TV still won't power up, but after reading about 7 hrs of threads I've conducted several test including
continuity of the power supply fuse - good
continuity of the power cord - good
I've also checked if there was any current actually coming from the power supply, so I tested all the outputs from the power supply board to the inverter board. On that side of the board is 24V and the ground, which tested with a multimeter gave me 24V for each wire.
I then checked the other side of the power board which as the 5V, 12V standby and 24V. Besides the 12V showing a voltage of 2.635 and stand by showing a voltage of 2.413 the 5V and the 24V showed up on the power supply as well as the main board.
So now I'm hear ...
I've included a bunch a pics
Any help will be appreciate, thank you and sorry for the long description of my problem.
P.S.
1. I used generic caps for the inverter board being that I got them from an electronic shop and the guy said that they were good for the tv
2. I used 2 caps from radio shack, 1000uf 25V and 470uf 35V, which are the exact uf but higher voltage than the original but its temp resistance isn't 105c but 85c
So now I'm hear ...
P.S.
