Westinghouse LTV-32W6 intermittent fault
  • rubicondsrv
    • Nov 2010
    • 39
    Customer requested that I service this unit due to an intermitent failure to turn on properly.
    Unit will turn on, and then after a few minutes the screen turns off, but blue power light stays on.
    Sometimes the screen fails to turn on at all, but blue light still comes on.
    Inspected power supply, no bulging or leaking caps, all rubycons.
    I suspect a fault in the logic board, and am planing on updating the firmware to see if that resolves the issue.
  • rubicondsrv
    • Nov 2010
    • 39
    Re: Westinghouse LTV-32W6 intermittent fault
    no firmware was avalible, is it possible that this is an inverter issue?
    I want to be sure before ordering parts
    • rubicondsrv
      • Nov 2010
      • 39
      one of the inverters is running warmer than the others.
      • mockingbird
        • Dec 2008
        • 5488
        Can we have a pic of these "Rubycons" on the PCB? I have an inklink that they are fake.
        • rubicondsrv
          • Nov 2010
          • 39
          ok ill get pics when i can......just ran it with the inverters disconnected and it just quit again.
          I guess that rules out inverters
          • rubicondsrv
            • Nov 2010
            • 39
            pics of caps
            • mockingbird
              • Dec 2008
              • 5488
              They look ok. The bunge (Underneath the cap), well at least the Nichicon which is sideway soldered so you can see it, what does that look like?
              • rubicondsrv
                • Nov 2010
                • 39
                looks fine, no leaks or bulging
                also when the unit cuts out, the blue power light stays on, and the tv must be unpluged and reconected before ot will start again
                • mockingbird
                  • Dec 2008
                  • 5488
                  But what does it look like... the underside of the nichicon.
                  Do the bunges look like this:
                  Or like this:
                  • PlainBill
                    • Feb 2009
                    • 7034
                    One possible cause of those symptoms is a failing voltage regulator on the main board. Check the output voltages.
                    PlainBill
                    • rubicondsrv
                      • Nov 2010
                      • 39
                      where do i check the voltages, and what should they read?
                      • rubicondsrv
                        • Nov 2010
                        • 39
                        main board
                        • PlainBill
                          • Feb 2009
                          • 7034
                          main board
                          Good move; I was going to comment that it helps to have a picture. I've circled them. For each one, identify the part number. Select a convenient ground point, and measure the voltage on each pin. Post the part number and the voltages you measured. Repeat after the TV fails.
                          PlainBill
                          • rubicondsrv
                            • Nov 2010
                            • 39
                            well, so far i havent been able to get readings off it, but got new symptoms...
                            it now wolnt recognise hdmi signals from my computer, claiming invalid format before shutting off.
                            honestly, im not interested in reparing the main board but just need to verify that it is the fault so i can replace it.
                            it also wolnt turn off once it gose into fail mode, i have to unplug it to turn it off.
                            • rubicondsrv
                              • Nov 2010
                              • 39
                              ok, i have voltages amd part numbers for the circled parts, but no voltages for when the unit is failed, because now it refuses to go out.
                              7805bd2t
                              2.03,6.54
                              1084-33pm
                              -3, 1.9
                              LD1085
                              1.88, -1.68
                              fr9024n
                              7.68,9.27
                              4.67, 9.27
                              • rubicondsrv
                                • Nov 2010
                                • 39
                                and it now is working perfectly......
                                but i did nothing except test the voltages
                                It even turns off and back on without trouble right now...
                                I guess i might need to just replace the main board and hope it is fixed, though Id hate to do that without knowing that it would stay fixed.
                                • mockingbird
                                  • Dec 2008
                                  • 5488
                                  That means your caps are the problem I reckon.
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Ahh - no. Far more likely that the problem is a lead-free solder joint; the flexing of the board as the testing was done caused two points to make contact. Now they are waiting until the back is on and the TV is in the family room before parting company again.
                                    PlainBill
                                    • rubicondsrv
                                      • Nov 2010
                                      • 39
                                      PlainBill
                                      that makes sense, when I was checking voltages and it refused to fail the tv was laying flat. when it failed, it was usualy upright.
                                      Unfortunately I dont have the equiptment to reflow the bga and surface mount parts properly, so i will have to replace the main board.
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        That seems more practical than mounting it on the ceiling.
                                        PlainBill
                                        • Rictech
                                          Panasonic SA-MAX770PU SMPSU board fault....
                                          by Rictech
                                          Hello everyone. 😀
                                          As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                          Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                          Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                          This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                          There are no devices that have exploded or otherwise show signs...
                                          08-26-2024, 01:05 AM
                                        • protocold
                                          MacBook Pro 15" 2010 820-2850 intermittent charging
                                          by protocold
                                          I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                                          I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                                          when it is not intermittent:
                                          PPVBAT_G3H_CHGR_R is 12.07v
                                          when it is intermittent:
                                          When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                                          when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                                          data line on the battery...
                                          07-25-2025, 08:18 PM
                                        • CDNBrewer
                                          Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                          by CDNBrewer
                                          Hello Everyone,
                                          I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                          Symptoms:
                                          • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                          • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                          • I swapped the Left and Right surround
                                          08-05-2025, 09:29 PM
                                        • howardc64
                                          Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                          by howardc64
                                          • Prior owner tried a replacement main board. No difference.
                                          • Samsung 2x red blinking standby LED = panel fault
                                          • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                          • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                          • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                          07-19-2025, 10:54 PM
                                          ESR meter came to the rescue again today with a PLC I/O card fault
                                          by sam_sam_sam
                                          I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                          I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                          One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                          12-18-2023, 08:17 PM
