kdl-32xbr4
  • cadiman
    • Mar 2010
    • 397
    kdl-32xbr4
    I picked up this sony 32 lcd (kdl-32xbr4) and it has a t-con board failure.
    I don`t see any of these boards anywhere new or used. I am thinking this is only sold with the panel since it does not have sony written on it anywhere.
    I found the parts breakdown on a Sears parts website and they didn`t list the t-con board or even show it.
    Also seems to be a high failure part. Does anyone know where I can find these? (I looked on ebay)
    Thanks!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: kdl-32xbr4
    What is the tcon part number? And can you include a picture using manage attachments?
    --- begin sig file ---
    --- end sig file ---
    • cadiman
      • Mar 2010
      • 397
      Re: kdl-32xbr4
      I am working on pictures. I really would like to post some, but this forum has some tough photopolice like I have never seen and I don`t want to mess up.
      This whole tv is a sony except for the t-con board. It has a chip by samsung on it. I thinks it goes with the panel.
      The sony part number is 1-789-796-11 I think I found it at Encompass for around 180.00 with core exchange.
      • Daren87
        Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
        by Daren87
        I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
        08-13-2023, 03:25 PM
      • thelankanguy
        Sony KD-55X9000F TCON Issue
        by thelankanguy
        The TV shows a black screen with no image.
        TCON ribbon connectors were disconnected individually for image and there was no half image even.
        Later both ribbons were disconnected and TCON voltages were tested.
        12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
        There is also a short to ground in this circled inductor.
        Is this a TCON issue or something else ?...
        12-13-2024, 12:27 AM
      • bbrain
        Sony KD-55AG9 TCON?
        by bbrain
        I have this problem with my Sony 55' AG9.
        It flashes 4x.
        I have found the service manual, and seems it is the TCON.
        Before I buy a TCON can someone check the vid?
        Thanks in advance!...
        09-19-2024, 10:50 AM
      • delpiero3
        Sony Vaio SVS MBX-261 board failure
        by delpiero3
        Hi everyone, newcomer in this forum, i watched tons of video from Sorin, i like the way i calmly explain things, i did quite some console repair, i am not that bad at micro-soldering, but troubleshooting where the issue is, is definitely where i still have progress to make. Usually i was able to fix the console because the failure was obvious, or because i was able to find someone with similar measures on the board and was pinpointing what to replace that way.
        Nevertheless, let's say, i don't come as a total beginner.
        I have this old laptop, which suit perfectly my needs, with the...
        10-29-2024, 06:16 AM
      • rimwall
        Sony KD-65x8500b - bad Tcon or panel?
        by rimwall
        Hi, hoping for some views on this one which I've not come across before. The TV generates an image that has 12 noticeable bands across it. The image is still there and accurate, but the colour (or perhaps the brightness) changes gradually across each band which creates a noticeable 'step change' at the edge of each band. Given it's a 4K TV with 2160 rows of pixels, I'm guessing the 12 bands correspond to 12 gate drivers of 180 rows each. If this guess is right, then perhaps:
        a) all the gate drivers are malfunctioning the same way (which seems unlikely), or
        b) the Tcon board is malfunctioning,...
        10-24-2023, 07:58 PM
